Old 05-31-2014, 08:40 PM   #1
32 chevy vett
32 chevy vett's Avatar
Default Tank to remove rust
I made up this tank to soak parts to remove rust 1 part molasses 7 parts water.
Put parts to clean in and let set for 2 to 3 weeks take out and pressure wash.
Nice part its green friendly.
32 chevy vett is offline   Reply With Quote
Old 05-31-2014, 11:03 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Tank to remove rust
Post a pic when it is de-rusted, looks interesting.
J Franklin is online now   Reply With Quote
Old 06-01-2014, 12:04 AM   #3
Mike V. Florida
Mike V. Florida's Avatar
Got a lot of tanks hanging around.
Old 06-01-2014, 07:35 AM   #4
32 chevy vett
I will post photos. It takes 2 or 3 weeks for it to work.
Old 06-10-2014, 10:12 AM   #5
Lowell Fast
I buy the dry molasses at Tractor Supply as horse feed supplement.
Lowell Fast is offline   Reply With Quote
Old 06-10-2014, 10:20 AM   #6
Lowell Fast
It was a Good idea to mount on the ground as this tank will really be heavy. Quickly Spray with a rust converter as soon as dry after pressure washing as it will flash rust quickly. Put the tank far from the house as wives can smell this process working although it does not smell bad to me till the enzymes are exhausted. Do not put any stippers or caustics in the mix as this slurry is actually alive.
Old 06-12-2014, 06:19 PM   #7
Lowell Fast
The Model A gas tank is a real pain to remove for derusting. What do you all think of placing the molasses solution in the tank while the gas tank is still in the cowl?
Old 06-12-2014, 07:12 PM   #8
TinCan
How much dry molasses to a gallon of water?
Pat
TinCan is offline   Reply With Quote
Old 06-13-2014, 09:15 AM   #9
32 chevy vett
Took the parts out and power washed them.The mix is 7 parts water to 1 part
molasses. I think it would work good on a gas tank as it will get in the inside of a door where you can not get with a sand blaster. And yes you have to hit the parts with a rust converter. I'am new at this so was not ready for the lite rust.
My friend hit his parts with a rust converter when he got home and said it cleaned up real good.
Old 06-13-2014, 09:22 AM   #10
32 chevy vett
Tin can I bought mine in 5 gal buckets. As for dry molasses I do not know.
Old 06-13-2014, 09:28 AM   #11
32 chevy vett
Lowell Fast after rereading yours I would NOT do it with out removing the tank. As you can not clean the top of the tank.
Old 06-13-2014, 10:59 PM   #12
Lowell Fast
The upper inside of the tank IS one of the worse places for rust due to condensation. I was planning to fill the tank with the mix, all the way to the top to get the top surface wet. I should have mentioned this stuff does not remove paint and all grease should be removed befor submerging. After rinsing off, it will start to lightly rust right befor your eyes.
Old 06-15-2014, 08:41 AM   #13
Steve Jelf
Steve Jelf's Avatar
Rust converter? Is that the same thing as metal prep, like DuPont 5717S, or something else?
Steve Jelf is offline   Reply With Quote
Old 06-30-2014, 10:49 PM   #14
FlatheadTed
FlatheadTed's Avatar
Any thing with Phos in the name, You might be better soaking in a warm caustic mix after ,its real hard to stop the molasses action ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
