08-14-2017, 04:07 PM | #1 |
Gear box replacement/modern alternative
Hi guys, Can anyone advise me on a modern replacement gearbox for my 29 A speedster. Currently I get arount 98mph using a high speed diff and three speed box but I think if if change to a 4 or 5 speed box i can improve. Also it will make cruising easier on the revs.
Thank you in advance. |
08-14-2017, 04:38 PM | #2 |
Re: Gear box replacement/modern alternative
08-15-2017, 02:29 PM | #3 |
Thank you.
08-15-2017, 02:34 PM | #4 |
Although my A will never hit 98 Miles Per hour I find absolutely no fault with Henry's transmission. If you want higher gearing why not install a Mitchell Gear Spliter or a quick change rear end? I get more speed out of mine by simply using 750x16 tires on the rear. :-)
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
08-16-2017, 04:18 PM | #5 |
Hello, the problem is when changing down at high revs, hill trials the gearing is wrong. But thank you for your input.
08-16-2017, 04:23 PM | #6 |
08-16-2017, 04:25 PM | #7 |
08-16-2017, 04:26 PM | #8 |
If you drive 98mph in a Model A, I don't think you are long for this world.
AL in NY |
08-16-2017, 07:37 PM | #9 |
Maybe he runs at Bonneville, or TROG?
08-16-2017, 08:46 PM | #10 |
It's a Speedster
08-17-2017, 04:21 PM | #11 |
19237884_1524314470964590_8640231646303142087_o.jpg, Thanks for the advice going to follow these up. Yes run at Pendine etc and its a speedster.
08-17-2017, 05:14 PM | #12 |
Some folks used to mate early '60's Peugeot 403 ? trannies to A's; I like the Ford F150 pickup setup.
The photo looks like a Bentley from the period ! |
08-17-2017, 07:17 PM | #13 |
Look for a Liberty or Doug Nash 5-speed. Basically it is a clutchless transmission during shifting.
