Old 02-14-2016, 12:02 AM   #21
KenCoupe
KenCoupe's Avatar
Default Re: ford speedster
Great looking car! Somebody mentioned similarity to '39 Bentley, and I see that, but I also see a little bit of three wheel Morgan in it too (might just be me).
KenCoupe is offline   Reply With Quote
Old 02-14-2016, 06:20 AM   #22
uk woodie
Marvin, its an ash frame clad in aluminium NO FIBRE!The chassis has been lowered by 4” and has extended front dum irons. It has also been modified to a longer wheel base. Model A Engine fitted with a Model B crank shaft
* Line bored shell bearings conversion to rods and mains
* Cross drilled crank shaft
* Lightened flywheel
* Fully balanced
* Mild camshaft
*Aluminium Cylinder head fitted – I.O.E type with 2” inlet valves
* Fully adjustable oil pressure relief
* Twin SU carbs
* 4 Branch balanced exhaust manifolds
* 2 ½” Exhaust System
* Mag Ignition
uk woodie is offline   Reply With Quote
Old 02-14-2016, 06:22 AM   #23
uk woodie
@ Glenn Very Nice station wagon, I love them.
Old 02-14-2016, 07:47 AM   #24
Patrick L.
Patrick L.'s Avatar
* Fully balanced
* Mild camshaft
* Twin SU carbs
* Mag Ignition
An IOE cylinder head ! Would sure like to see a picture of that and know who made it. Thats neat.
Old 02-14-2016, 08:13 AM   #25
Juggler
Juggler's Avatar
Pic from Pendine last year
Juggler is offline   Reply With Quote
Old 02-14-2016, 11:46 AM   #26
Marvin/TN
Send a message via AIM to Marvin/TN
OK thank you Woody, Did you form the metal or have it done, looks like a great job of making it. I have done Collision Repair for over 40 years but forming that boat tail is beyond my skills. I did make a 1/4 panel for a Desota once using door skins from some extra doors. It turned out pretty good and I think the fender skirts would even fit. The owner moved away before he finished the car. I didn't have the fender skirts to fit to the panel when I was putting everything together. I have a friend that can really fabricate sheet metal. He is doing a 53 Chev Convertible and has even made the 1/4panels from scratch.
Marvin/TN is offline   Reply With Quote
Old 02-14-2016, 11:56 AM   #27
Model A Man
Model A Man's Avatar
Originally Posted by hale1776 View Post
Coachwork is first rate, possible the nicest speedster I have ever seen.
I agree. Would love to have a set of plans for this one.
Model A Man is offline   Reply With Quote
Old 02-14-2016, 12:02 PM   #28
uk woodie
Sadly, I am unable to claim the credit for the work. I have taken a body that needed finishing, and improved the aesthetics, the engine was also there in its converted form but sadly needed a lot of work to 'finish' it. The teething troubles turned into many pounds worth of restitutions that should have been easy fixes when created. I experienced a tremendous learning curve but ultimately have a much better grasp of Model A's.
Old 02-14-2016, 12:06 PM   #29
uk woodie
Thanks Juggs, (wish I had given it a clean first!) and thanks for the info on my woodie.
Old 02-14-2016, 03:27 PM   #30
Patrick L.
Patrick L.'s Avatar
Wow, sure is something one doesn't see everyday.
Old 02-14-2016, 03:51 PM   #31
Juggler
Juggler's Avatar
I think they (Belcher Engineering in UK) only made 6 of them. I know the whereabouts of 3 running in cars and another (maybe) still under a bed, but the others who knows?
Combustion chambers modelled on McKee (sp?) heads which again are pretty rare
Old 02-15-2016, 02:52 PM   #32
wensum
wensum's Avatar
Left hand drive must make life so much easier!
For us RHDers we have the exhaust and the steering box on the same side.
It one wants to retain the original steering and light switch, free flow exhausts are a problem unless you poke the straight out the side of the bonnet(Hood?)
It looks so simple in the photo.
Keith
wensum is offline   Reply With Quote
Old 02-26-2016, 11:10 PM   #33
QGolden
QGolden's Avatar
Very nice Speedster. Does it currently have the mudguards attached? If so I would love to see a picture of the mounts for them. Thank you in advance.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 02-28-2016, 04:28 AM   #34
uk woodie
Hi, yes they are attached, i had them fabricated, then the brackets are welded to the back on the brake drum so the turn with the wheel.
Old 02-28-2016, 08:08 AM   #35
Tony S,Fl.
Tony S,Fl.'s Avatar
NOW that's a speedster. Excellent . Tony
Tony S,Fl. is offline   Reply With Quote
Old 03-12-2016, 04:45 AM   #36
updraught
updraught's Avatar
Here is a 1.16 million (pound?) version, before the insurance bill ...
http://pursuitist.com/rare-bentley-w...s-up-for-sale/
updraught is offline   Reply With Quote
