12-14-2019, 07:33 PM | #1 |
Bren carrier engines
Hello - this is my first post here. I'm looking for an engine I could use in a Bren/Universal carrier. There are a ton of old Ford Flathead V8s out here but i'm a bit confused about which ones I could use in a carrier.
Can anyone tell me what the differences are between a regular Ford Flathead V8 and those used in bren carriers? I'm told the later 8BA engine sumps are too deep and to use one a hole has to be cut in the carrier floor. My understanding is the engine I need is a model 81A 239 cu" 3.9L. Can I use a smaller 211 cu"? I think I can, it will be lower power but does it really matter? From what I can see below I can use any pre 8BA Ford Flathead engine... Is that info correct? There is a 1947 59AB flathead complete with transmission near me which might work if that's the case. The LP2 and LP2A's had a 95 hp 24 stud truck engine. The Canadian carriers (Universal Mk1*) were 85 h.p. 21 stud, but later on some units had their replaced with 24 stud motors. The British Carriers are identified as No.1 MkI, or No.2, MkI., or No.3, Mk1. etc.etc etc. (is that o.k. Michael?) This will likely raise an arguement, but at least in Jan. 1943 (the date of the Chilwell, Universal carriers, workshop instruction book. the book clearly states on page 3; No.1 is the 65 hp engine, (21 stud, 18mm plugs) No.2 is the 85 hp engine, and (21 stud,18 and 14mm plugs) No.3 is the 95 hp engine (24 stud, 14mm plugs) I have added the comments in brackets. Pretty much everything Ford had built by 1945, had been used in carriers. I'm sorry about all the questions, I hope someone doesn't mind having a go at answering some of them. |
