Old 07-20-2019, 10:57 PM   #1
oldcarnut47
Default 1953 crestline heder panel molding same as 54 ?
I need the header panel molding that goes above the grill and down the front of the front fenders but all i have been able to find is the 54 molding quite a drive so i would like to find out if the 54 molding will work on my 53 before i make the journey.
Thanks in advance
Oldcarnut47
oldcarnut47 is offline   Reply With Quote
Old 07-22-2019, 06:00 AM   #2
KULTULZ
KULTULZ's Avatar
Post Re: 1953 crestline heder panel molding same as 54 ?
The PN INFO was removed from the 49/59 MPC and one would need an early 50'S BODY CATALOG to see if they are actually the same.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 07-22-2019, 12:14 PM   #3
54vicky
54vicky's Avatar
Default Re: 1953 crestline heder panel molding same as 54 ?
it will not work they are different in that the 53 is a two piece while the 54 is one piece the panel is also quite different.changing the panel and trim together will not work either as they differ quite a bit
54vicky is offline   Reply With Quote
Old 07-22-2019, 03:26 PM   #4
JeffB2
JeffB2's Avatar
Thanks in advance
Oldcarnut47
You can probably find a '53 molding here: https://www.facebook.com/watch/?v=347866255934591
JeffB2 is offline   Reply With Quote
