Old 08-26-2019, 07:27 AM   #1
russcc
Default '40 O1A-2473 pedal - shaft
Can the shaft in the pedal casting on the '40 be removed ? If so is the shaft available ? Thank you Fordbarners
Old 08-26-2019, 07:32 AM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: '40 O1A-2473 pedal - shaft
Yes and new ones are available. Just make sure when you press in the new one it’s equal on each side for the pedals
Old 08-27-2019, 06:41 AM   #3
russcc
Does someone like Fred Wilner at SSO have those shafts ?
Old 08-27-2019, 09:20 AM   #4
texas webb
Might check with Van Pelts also.
texas webb is offline   Reply With Quote
Old 08-27-2019, 09:47 AM   #5
skidmarks
skidmarks's Avatar
And support the bracket when you press the new one in and the old one out.
It's not super tight
I think the last one I changed I got the shaft from Dennis carpenter
skidmarks is offline   Reply With Quote
Old 08-27-2019, 07:15 PM   #6
Kube
Kube's Avatar
Carpenter sells them. About $18
Old 08-27-2019, 11:34 PM   #7
1952henry
1952henry's Avatar
[QUOTE=skidmarks;1792505]And support the bracket when you press the new one in and the old one out.
I think the last one I changed I got the shaft from Dennis carpenter[/QUOTe
That last sentence could be taken the wrong way
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 08-28-2019, 06:07 AM   #8
skidmarks
skidmarks's Avatar
[QUOTE=1952henry;1792738]
Right, but if was to be taken that way. A more accurate depiction would replace Carpenter with Drake or Speedway motors.
Old 08-28-2019, 02:49 PM   #9
1952henry
1952henry's Avatar
True. Wasn't meant as jab to dc.
