08-23-2019, 05:52 PM | #1 |
heater wiring
Have a 47 car and was wondering where the best way to place to get power to my heater ? Do I just get power from the ignition switch or from some other source ?
08-23-2019, 06:42 PM | #2 |
Re: heater wiring
These may help.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
08-23-2019, 08:46 PM | #3 |
Re: heater wiring
do not take the power off the "coil" side of the ign switch. I went back to the circuit breaker under the dash and then routed it thru a fuse to the heater
08-24-2019, 12:18 AM | #4 |
Re: heater wiring
With the switch turn on, would that make the heater only work when the ignition is in the on position or on all the time ?
08-24-2019, 07:51 AM | #5 |
Re: heater wiring
THANK YOU Forty Niner!!!!!!!!!!!!!! Included in that batch of information is the elusive code for wiring a 46-8 heater switch which a lot of us have been looking for.
08-24-2019, 12:46 PM | #6 |
Re: heater wiring
08-24-2019, 01:46 PM | #7 |
Re: heater wiring
Not trying to be redundant but, here's more info.
https://www.earlyfordv8.org/forum/pr...=18&Topic=1692 Will the posting #10 help? https://www.fordbarn.com/forum/showt...ht=wire+heater Last edited by 19Fordy; 08-24-2019 at 01:52 PM. |
08-24-2019, 07:48 PM | #8 |
Re: heater wiring
Any problems with the power being hook up to the ignition switch ?
08-24-2019, 09:13 PM | #9 |
Re: heater wiring
Heater and fans are high current users, why would you want to attempt to connect them to the ignition switch? The ignition switch is not designed to handle high current loads.
08-25-2019, 06:08 PM | #10 |
Re: heater wiring
Thank you, JSeery thats what I was looking for. Moe
08-25-2019, 06:54 PM | #11 |
Re: heater wiring
Just had a thought, how would you hook it up if a person wanted the heater to only work when the ignition was on ?
08-25-2019, 06:56 PM | #12 |
Re: heater wiring
Relays, just like a fuel pump or something. Relays are handy little things for this type of stuff. Use a wire from the ignition switch as the trigger wire.
08-25-2019, 07:05 PM | #13 |
Re: heater wiring
Here are the 1945 instructions, see the paragraph on switch connections. It tells you to connect to the red and black wire on the fuse block so the heater will only go when ignition is on. If you need this in higher resolution send me your email address and I can email it to you.
Hope this helps?
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand https://www.fordbarn.com/forum/album.php?albumid=580 Last edited by meric42; 08-25-2019 at 08:30 PM. Reason: Spelling |
08-25-2019, 07:51 PM | #14 |
Re: heater wiring
It sure does say that!! The Red/Black wire is the wire from the ignition switch to the resistor on the fuse panel. I don't think that is a good idea at all!!! But, this is what the instructions say.
They say to connect to the Red/Black wire on the ignition switch for the Ford and to the fuse panel on the Merc. Last edited by JSeery; 08-25-2019 at 07:59 PM. |
