01-05-2020, 07:47 AM | #1 |
Wood floorboard steel supports.
Are the tubular rivets that come with the pair of steel floorboard supports easy to install and peen? If not a judged car do most use just a woodscrew? Same with the transmission/brake handle cover hold downs.
"Never complain,never explain"... Henry Ford II |
01-05-2020, 09:14 AM | #2 |
Re: Wood floorboard steel supports.
the rivet setting tool is the same as for brake lining rivets. i would check with a local club and see if you can barrow one from them. or you can make your own rivet setting tool out of a punch. it will not be pretty but it will work.
01-05-2020, 10:08 AM | #3 |
This is a link to Hanson Rivet and one of their tubular rivet tools. They have different tools for the different diameters of tubular rivet. Not necessarily a plug for Hanson but a good illustration of what the hand tools look like.
https://www.erivet.com/product_detai...itemNbr=HT-174 |
01-05-2020, 12:26 PM | #4 |
