01-22-2013, 02:24 PM | #1 |
1931 Steering Wheel
I am filling the numerous cracks in the steering wheel. It is the first time I have used JB Weld, a very good product. I will be shaping the repairs soon and I would like some suggestions on how to cut the four circular lines on the wheel, maybe using a Dremel. Thanks, Ed
01-22-2013, 02:30 PM | #2 |
Re: 1931 Steering Wheel
Can you use a flat board and bore a hole for either a wooden dowel or a pipe that has the same size as the steering column hole. Then use that as an axis to spin the wheel on. Now make a steady rest out of some blocks to clamp onto the board where you can spin the steering wheel slowly while the grinder grooves a uniform slot.
01-22-2013, 03:43 PM | #3 |
https://www.fordbarn.com/forum/showth...steering+wheel Good luck Ed
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
