Old 01-24-2021, 07:36 PM   #1
wright-47
Default Sound deadning
Has anyone used Acoustishield and what do you think of it? Is there anything else out there that would look like the original material? I don't mind cutting to fit if I can find it. Thanks in advance.
wright-47 is offline   Reply With Quote
Old 01-25-2021, 10:10 AM   #2
woodiewagon46
Default Re: Sound deadning
I have been using a sound deadener product from 3M, part no. 3M-08840. It comes in 19" square sheets, self adhering and comes 10 sheets in a box for about $75. A lot cheaper than some of the stuff on the market. I found that it works very well.
woodiewagon46 is offline   Reply With Quote
Old 01-25-2021, 11:14 AM   #3
tubman
tubman's Avatar
I remember seeing a bunch of threads on the "H.A.M.B." on this subject. As I remember, there are a number of products sold at "Home Stores" that are much cheaper and actually work better.
I suggest you check over there.
Old 01-25-2021, 11:36 AM   #4
blucar
blucar's Avatar
Dynamat is probably the most well known and commonly used sound deadening/heat blocker used in the custom car world, however, as we all know Dynamat is very expensive.
My upholster turned me on to a product called Road-kill, the product is very similar to Drynamat and can be purchased on-line from many vendors for about half the cost of Dynamat.
I have used Road-Kill in three vehicles since '09, getting ready to use it in a forth vehicle.
I just looked Roadkill up on ebay.. It is listed under Stinger Roadkill sound deadening. Comes in 18"x32" sheets. If you buy the self adhesive type of sound deadening make sure you buy a good plastic wheeled roller. I bought a wooden wheeled roller for my fist job, it fell apart halfway through the job.
Bill.... 36 5 win cpe
blucar is offline   Reply With Quote
Old 01-25-2021, 12:29 PM   #5
Kube
Kube's Avatar
Tubman, That's the stuff I have been using for years (decades actually) without an issue.
Old 01-25-2021, 03:06 PM   #6
flatford8
flatford8's Avatar
That’s the same stuff I used on my ‘50. I think the roll was 4’x 50’. I used 3M spray adhesive and it worked very well.......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 01-25-2021, 03:17 PM   #7
sidevalve8ba
sidevalve8ba's Avatar
Kube, Is what you use self-adhesive?
sidevalve8ba is offline   Reply With Quote
Old 01-25-2021, 03:30 PM   #8
Lawson Cox
Lawson Cox's Avatar
A gallon bucket of roofing tar at Home Depot is inexpensive and is very close to what Henry used. All of this "Modern Crap" is more expensive, harder to use, and is NOWHERE close to being original or any better. My 2¢. (But what does an Old Foggie like me know?)
Old 01-25-2021, 04:25 PM   #9
Kube
Kube's Avatar
Nope. I use 3M contact cement, brush on.
Old 01-25-2021, 07:02 PM   #10
1941Pony
I’ve used the home store stuff before, mid engine Boxster. Worked well on keeping the heat and sound level down to a noticeable improvement. The foam stuff works better for sound.
1941Pony is offline   Reply With Quote
Old 01-25-2021, 08:46 PM   #11
GB SISSON
GB SISSON's Avatar
While I can't remember the two brand names I bought last summer, one was way heavier than the other. We are talking about a cummins diesel in a '47 Ford tonner. My local hardware store has something that looks like bubble wrap with foil on it.... Did nothing for noise. In the 70's I worked for a sailboat builder in SW Harbor Maine. High end stuff. They liked westerbeke diesels and they were mounted right in the galley next to you behind a ladder. The entire engine compartment was lined in what we called 'lead foam' material. Shut the hatch on that westerbeke and you could hear yourself think. It would best be described as neoprene wet suit material, like 1/8" each side with lead sheet core at about 1/16th". Probably wasn't cheap, but it really worked. I tried to find it for my diesel converted ford, but maybe because of lead, it isn't around any more. Shame because it isn't gonna get into our bloodstream inside that foam, and what about our hearing? My TV is at 22 right now,
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 01-25-2021, 10:03 PM   #12
gasserdays
Do not use the Eastwood stuff. It bleeds out black oily thick tar after a while.
gasserdays is offline   Reply With Quote
Old 01-26-2021, 09:58 AM   #13
Zax40
Zax40's Avatar
I think they have new versions now that no longer do that, but probably not worth the risk.
I've heard good things about the Kilmat product if you are looking for the self stick type that is not as pricey as Dynamat.
Zax40 is offline   Reply With Quote
Old 01-26-2021, 10:29 AM   #14
TJ
TJ's Avatar
Absolutely correct. Friend put it in his car and had to take it all out due to the stuff bleeding out and creating a huge mess. Don't know if they have cured the problem or not.
Old 01-26-2021, 10:31 AM   #15
36and63
36and63's Avatar
I've used Eastwood XMAT for over 10 years without any issues. No smell and works well to reduce heat and sound.
Pat
36and63 is offline   Reply With Quote
Old 01-26-2021, 12:21 PM   #16
cas3
i used some stuff from Lowes recommended by some guys on the hamb. I believe its actually made for patching leaky gutters, foil faced, rubber kinda stuff with adhesive. guys in hot climates claim it has never fallen off from the heat. comes in rolls 6" wide, and cheap. cant say any specs on sound or insulation, but it took the "tin can" sound away when you slam the door
cas3 is online now   Reply With Quote
