Old 06-01-2021, 08:39 PM   #21
Shu47
Shu47's Avatar
Default Re: Shoebox pulling a Teardrop
I think it would be worth running a test with the bug screen removed just to see what happens. If it doesn't help reduce the temp then you know the bug screen doesn't hurt airflow but if it does then at least you know and can take whatever action you decide.
Shu47 is offline   Reply With Quote
Old 06-01-2021, 08:43 PM   #22
Lawrie
Lawrie's Avatar
Our 33 with a 99a 265 ci engine 3.78 rear end tows the caravan that weighs about 900kg at 50-55 mph all day in 35 -40C days , stock cooling with stock fan on the generator ,never over heats, most times around 75-85 C.
Lawrie
Lawrie is offline   Reply With Quote
Old 06-01-2021, 10:06 PM   #23
cas3
Put some miles on the car to see if compression improves
Thread Tools
Display Modes
