10-07-2019, 02:21 PM | #1 |
stubborn rear brake drum seal removal
took a few tries, but eventually I won the day. for some odd reason the fronts were not an issue.
attempting to simply pry with a long screwdriver only deformed the side wall of the seal. needle nose vice grips just took a bite out of the wall of the seal. |
10-07-2019, 02:23 PM | #2 |
Re: stubborn rear brake drum seal removal
hmmm... OK, let's drill a small hole & see if I can pry it out with a punch / drift.
no joy. |
10-07-2019, 02:25 PM | #3 |
it was suggested to simply drop the drum on the pavement. (the weight of the bearing would do the trick ?)
did a good job of shredding the paper. |
10-07-2019, 02:39 PM | #4 |
full jaw vice grips. drive the lower jaw into the seal as far as possible. lock the jaws and whack the end of the vice grips several times.
for the second drum I'll buffer the vice grips with a piece of thick leather at the edge of the seal opening. I did deform the channel for the snap ring slightly. I oriented the void in the snap ring to this area. it's 5:00 somewhere |
10-07-2019, 03:11 PM | #5 | |
10-07-2019, 05:20 PM | #6 |
10-08-2019, 04:33 AM | #7 |
And I picked up a helpful hint here on the forum:
To drive in the new seal, assuming you don’t have a seal driver kit, a short pvc pipe connector (2 inch inside diameter 92 cents at Home Depot), is the perfect size to evenly tap the seal in. Just get it lined up and carefully use your hammer. Works like a charm. |
10-08-2019, 02:21 PM | #8 |
Gee, To remove the seal I just inserted a long,thin tapered drift punch and tapped it out.
10-08-2019, 03:41 PM | #9 |
On my 39 I used two small screwdrivers to pry it out. You have to be careful not to distort it.
10-10-2019, 07:17 AM | #10 |
You can easily do that on front drum/hubs, but not so easily done on the rear drum/hubs from 32 to 48, IMHO.
02-23-2020, 03:47 PM | #11 |
Would there be a way to remove the seal and reuse it
02-23-2020, 05:14 PM | #12 |
No, but anyway it wouldn't be worth the effort or wisdom to use the old worn-out seal.
02-24-2020, 05:24 PM | #13 |
You can reuse the seal if you use the K R Wilson bearing remover.
02-24-2020, 10:12 PM | #14 |
02-24-2020, 10:38 PM | #15 |
Maybe because a good original used seal is better than a new replacement of unknown origin and quality?
Just playing Devil's Advocate here. |
02-24-2020, 11:31 PM | #16 |
02-25-2020, 02:33 AM | #17 |
I think the OEM seals were leather. Surely, the new neoprene seals are better.
02-25-2020, 10:35 AM | #18 |
New seals are much better than doing the job over.
