05-23-2013, 10:39 AM | #1 |
Question for Tom Endy
I am preparing to set up my differential according to your excellent and thorough instructions.
I am unable to obtain a spare spider yoke that you use as a special tool. The suppliers do not list that item. Is there an acceptable work-around for this ? Thank you. dave
'31 180A |
05-23-2013, 10:42 AM | #2 |
Re: Question for Tom Endy
Want one, ...or two, ....or three....?
Seriously, surely someone in the DFW area has a torn-apart, greasy, nasty differential laying around that they would donate to your cause. |
05-23-2013, 10:52 AM | #3 |
Hey Dave... How's the ice cream truck coming along?
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
05-23-2013, 03:09 PM | #4 |
I suspect you could modify the yoke you are going to install in the car. Drill a hole through the flat side and tap it for the threaded stock, which is the other part of the tool. The hole in the yoke should not create a problem. The flat side of both axles runs against it and probably won't care if there is a hole in the yoke. Attached photo is of a carrier with the hub on the ring gear side sheared off. This came out of a car that was running just fine. The owner was having an overdrive installed and wanted the rear axle assembly overhauled as a precaution. When I took it apart the bearing with a portion of the hub in it fell out. I suspect who ever had it apart before did not know about pre-load and put a gasket on each side and bolted it up. It was probably locked up when assembled. In most cases it would have spun the bearing on the hub. In this case it just sheared the hub off. Tom Endy |
