Old 01-23-2019, 06:18 PM   #1
Dutchwonder
Dutchwonder's Avatar
Default Another 8BA ID question...
Hi there,
It's been a couple years since I last was on here. However I now have a garage and have begun disassembly on my 49. I have a couple questions on the engine. So it's a 49 Tudor Custom my grandpa bought in 50. The engine is blue, so its early. What I cannot find out is if these numbers mean anything.
What does the F and the NO289 below it mean (it looks like its a screwed in plate?). Also does this number on the Intake mean anything?
Thanks!
"By Perseverance the snail reached the ark."
Dutchwonder is offline   Reply With Quote
Old 01-23-2019, 07:19 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Another 8BA ID question...
casting pattern #, casting batch # most likely
Old 01-23-2019, 07:25 PM   #3
tubman
tubman's Avatar
Again, the only numbers that can give any more information are those that may (or may not) be stamped on the intake manifold surface on the block. If they are there, there is information that will allow you to determine the assembly date of the engine.
Old 01-23-2019, 09:07 PM   #4
51 MERC-CT
51 MERC-CT's Avatar
If the heads do not have dedicated boss holes to mount an oil filter then the heads are most likely '49.
Old 01-24-2019, 07:30 AM   #5
19Fordy
19Fordy's Avatar
8RT means that it can be used on a pick up truck also.
