10-03-2021, 08:32 PM | #1 |
New KYB front shocks
Ok, the KYB 4515 shock which are correct according them aren’t quite correct as people have said. I wasn’t totally in agreement with cutting open the blade ends of the shock and as a matter of fact KYB said not to do that.
So I emailed them and they suggested a slightly different shock. 4752 fits Toyota trucks and is almost identical in length and stroke. It is about 10mm shorter but has about 15% more damping according to their tech dept. Here is the nice part though, the over all width of the blade is the same but the holes where the bolts go are 10mm wider. So this shock is a direct bolt in without having to modify the shock at all. So tomorrow I will bolt them in and see how they fit. I won’t know how they handle for several months but I wanted to pass this info along if it has not been passed along before. Mike
10-03-2021, 08:57 PM | #2 | |
Re: New KYB front shocks
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
10-03-2021, 10:22 PM | #3 |
Apparently the way to use the 4515 is to cut open the ends of the blades where the bolts go. It allows you to widen the bolt pattern. I just was a little worried that the shock could come loose. Not sure if it was paranoia or not.
Mike
10-04-2021, 12:10 PM | #4 | |
THANX! for the PN update. It will help many I would think.
10-04-2021, 06:17 PM | #5 |
The 4515 is the their correct part number for our application. Here is the tech response:
Hi Mike, We haven’t had this issue before, but if you have the tools to do so, you would be safe to use a file to widen the mounting holes (along the length of the t-bar) so that they match up better with the bolting points on the vehicle frame. Don’t drill out the holes though so you can use the same bolting points. KG4752 is very similar to KG4515, but the holes in the mounting bar are about 10mm (3/8”) further apart so it could be a better fit. Only thing is that the damping rate is about 15% higher than KG4515, so you will have a firmer ride as a result. Regards, Technical Support KYB Americas Corporation [email protected]
10-04-2021, 07:45 PM | #6 | |
EDIT - Originating Companion Thread - https://www.fordbarn.com/forum/showthread.php?t=304170
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 10-05-2021 at 05:12 AM. Reason: INCLUDE ORIGIONAL THREAD |
