02-03-2018, 10:15 PM | #1 |
Anyone around Chicago "qualified" to machine an 8ba block?
Hello; does anyone out there know of a shop that has dealt with flat head engines and knows how to correctly machine an 8ba block... Cylinders, decking the block, valve seats, and a valve job? Thanks, Steve
02-03-2018, 11:05 PM | #2 |
Re: Anyone around Chicago "qualified" to machine an 8ba block?
Fox Valley Hot Rods in Barrington, Il. Ask for Matt.
02-04-2018, 08:10 AM | #3 |
Steve I would also recommend Matt at fox valley Hot Rods . I would drop it off and check out the Ardun he a and his Dad is building . Mike Yank is a outstanding engine builder and a buddy's blown flathead that Mike built ,will smoke most small block Chevys away.
Wanted Roadster Pick up thank you COLOR] |
02-04-2018, 09:26 AM | #4 |
Where is Barrinton , I am in Okla. I don't mind traveling or a little freight, I have an 8ba I want a main support I bought from Mike Davison (Flattatack) fitted , I don't want an inexperienced machine shop to do it , all shops I have talked to want to line Hone it, Also have any of you folks had a crankshaft Tuffride processed? I don't want a catastrophic failure especially due to crankshaft failure.
Appreciate your input. Thanks, Fordestes |
02-04-2018, 07:30 PM | #5 |
Mike Yank....Mike Yank....Mike Yank...... I’ll say it again if you want. NOT the other guy!
02-04-2018, 07:55 PM | #6 |
02-04-2018, 08:38 PM | #7 |
Does Matt deal with ancient babbit blocks?
02-05-2018, 10:13 AM | #8 | |
There are now super precision CNC boring machines that can hold 1 - 2 tenths in the mains - and they have a 90 degree boring head on them - they do one bore at a time, then move on down the cap line. Most create such a perfectly round hole, with the right surface finish, that a line hone isn't even needed. I don't believe Fowler has one of these - but I've used them out West. Good luck! Last edited by Bored&Stroked; 02-05-2018 at 09:25 PM. |
02-05-2018, 10:25 AM | #9 |
Oh - on the crankshaft question. I recently had a 4 1/8 stroker Merc crank nitrided out in Colorado (can find the name of the place if you're still interested). I did this because I wanted to ensure I had a hard journal surface after the 1/8" offset grinding. It is in my 32 Cabriolet as I write. I've not torn it back down to inspect the bearings - as it only has about 1000 miles on it (at most).
Once you get it nitrided, it will need to go back on the journal polisher. There are at least three different "tufftride" and "nitriding" type processes - each has it's specific technical details. I can't remember which process was used on my Merc crank - but I can find out. Here is a picture of the crank (as I received it) - and after I'd spent some time doing some basic cleanup-polishing of all the crankshaft surfaces (obviously I didn't do the journals - I masked them off): CrankNitrided1 copy.jpg CrankNitrided2 copy.jpg CrankNitrided3 copy.jpg |
02-05-2018, 04:28 PM | #10 |
Auto Machine in St. Charles just did mine. They are fully equipped to do this and understand the nuances of a flat head ford. I disassembled mine myself and then had them go through it. Bored .040 and had to add one sleeve. Before they would bore it they wanted to have the pistons on hand so they could match to the cylinders. They also cut my crank and installed the cam bearings.
Very happy with the work. They have 32 3 window sitting in the shop now that is the owners and he is doing some major work to the bottom end to run a blower I think. |
02-05-2018, 05:19 PM | #11 |
I want to do this right , it will be a last hurrah for me as to a performance Flathead, I want it to stay together for a good while although it will be a street driven engine , I have a few leftover hotrod parts I am going to use up and keep a spare or two then sell off the rest. I never really understood the whole process of the nitride process , I learned many years ago about it and never really used it for myself, I understand it originated from German engineering. I may be traveling to the New England area and I can leave the engine then and maybe pick it up later , I have a main setup from Mike Davidson I never used so I am using it instead of just main caps or a splitter bolt strap on the center main, I have seen many times in Diesel and gas engines what a busted crank can destroy . this is overkill for a street engine but The parts are already paid for and will go to rust if I don't use them, B&S, What is your opinion on the Flatattack lifters? I think I have a couple sets somewhere on the shelves. I will be using a 471 Detroit blower and Mitchell intake with a wide choice of ignition systems and about any fuel delivery system as well, I am thinking a 6 Btm with a points type Mallory y c distributor/ need some input from any or all , I don't want to mess this up! I see where I think Dyers is offering a v- belt drive for the small blocks , I have a flathead drive hub already or just a cast iron small main Chev balancer that I can bore to fit the flattie. Thanks for your info , Fordestes
02-05-2018, 05:25 PM | #12 |
The 1/8th offset is what I have as well and the machine shop didn't polish it out ,( The older machinist passed away) this was probably his last stroker he ground , I waited a while before I took him a crank and almost waited too late, so nitride it is , do I need to have the crank polished before and after it is processed ? or both? I am building a 4" merc also , I may just have it nitride too. Thanks to all who have responded , I would like to get the contact info on the shops available to get this done before long.
Fordestes |
