Old 12-20-2018, 09:11 AM   #1
46woodie
Default 6V electric fuel pump suggestions
What brand and where should I buy a 6V fuel pump for my 46 wagon. Any suggestions for type of pump and mounting. Topic probably addressed a hundred times on here but want advice. Thank you!
46woodie is offline   Reply With Quote
Old 12-20-2018, 09:16 AM   #2
Pat/Ohio
Pat/Ohio's Avatar
Default Re: 6V electric fuel pump suggestions
Airtex E8902 pump (6V - low pressure). Usually can find on Amazon for around $30. Mount near the gas tank.
Pat/Ohio is offline   Reply With Quote
Old 12-20-2018, 10:15 AM   #3
JSeery
JSeery's Avatar
There are previous threads with a lot of discussion on mounting, wiring, etc for a fuel pump if you are interested in detailed information. The basics are as low and close to the fuel tank as practical. I would wire it using a relay. A relay would be wired to an always hot source for the input. Add a new fuse between the power source and the relay. I would not wire into the ignition switch, but if you do only use it for a relay trigger input. Need to decide if it is going to be electric fuel pump only or plumbed through the original fuel pump. And if you are going to run it full time or only to prime or for vapor lock. If you use a toggle switch you need a method (light or something) to let you know it is turned on! Very common to forget the electric pump is running.
Old 12-20-2018, 09:12 PM   #4
Tinker
Tinker's Avatar
No you should not. Talk to charlieNy and stop using eth fuel. Even the last pumps from macs have been working for 8yrs (fingers crossed)
Old 12-21-2018, 10:07 PM   #5
46woodie
Not sure I understand the relay part of installing this. Thanks
Old 12-22-2018, 12:20 AM   #6
Pete
Pete's Avatar
You wanted advice.
Use the search feature.
Merry Christmas.
Old 12-22-2018, 01:07 AM   #7
JSeery
JSeery's Avatar
You can wire it without a relay. Relays are just a good method.
Old 12-23-2018, 12:16 AM   #8
Kahuna
Kahuna's Avatar
I agree with JSeery
Use of a relay is smart & takes the load off the ignition switch, if you are using it to turn on the pump.
Seems like I remember a pump made by "Autopulse" when we were kids
Kahuna is offline   Reply With Quote
Old 12-23-2018, 02:17 AM   #9
Pete
Pete's Avatar
Nobody seems to remember one of the most important things to use with an electric fuel pump.
AN INERTIAL CUTOFF SWITCH!!!!!!!
You can get them at any junk yard for a couple bucks.
It could save your car from becoming a crispy critter.
Old 12-23-2018, 02:20 AM   #10
Tinker
Tinker's Avatar
think ol' henry, had a post on putting a aftermarket inertia switches, in case of a accident for full time electric full pumps. god forbid.
so far, hey how is heck is Vergil?
See post #35... still looking if Vergil ever posted a rundown on how-to.
https://www.fordbarn.com/forum/showt...+vergil&page=2
File Type: jpg Screen Shot 2018-12-23 at 1.30.13 AM.jpg (18.9 KB, 61 views)
Old 12-23-2018, 02:35 AM   #11
Tinker
Tinker's Avatar
I found it, ol'henry. not the first to do it, but he posted it. great idea for full time electric pumps.
Think Vergils setup was cleaner looking, Pete can you clarify or post a how-to thread?
https://www.fordbarn.com/forum/showthread.php?t=88677
Old 12-23-2018, 04:22 PM   #12
Pete
Pete's Avatar
" Pete can you clarify or post a how-to thread?"
First, an inertia switch is a device that is wired in series with the plus wire going to the fuel pump. If the switch which is mounted to the car in a protected place, receives a hard impact or the car rolls over, it will disconnect the circuit it is wired in. It needs to be reset manually.
Old 12-23-2018, 04:44 PM   #13
JSeery
JSeery's Avatar
I use both an oil pressure switch and an inertia switch.
Old 12-23-2018, 10:28 PM   #14
Tinker
Tinker's Avatar
Not sure if there is a tech post on installing either. I use only a mech pump, so I guess a oil pressure switch isn't a bad idea. Might be a bit of overkill for me as I'm just running a stocker warmed 60 over.
Granted; I inner city drove a Model A with a tank in the dash for a time too. Couldn't do anything about that.
Old 12-23-2018, 10:29 PM   #15
Tinker
Tinker's Avatar
A relay is just a low voltage electromagnetic switch.
Old 12-24-2018, 05:43 PM   #16
JSeery
JSeery's Avatar
An oil pressure switch shuts off an electric fuel pump if the engine is not running. With a mechinical pump you would need an intera switch along with a fuel line shutoff relay.
Old 12-25-2018, 09:34 PM   #17
40 Deluxe
If you keep the original mechanical pump and run the electric pump through the original pump, if the diaphragm fails you could pump the entire gas tank contents into the oil pan!
Old 12-26-2018, 05:49 PM   #18
woodiewagon46
Excellent advice by JSeery, if you are involved in a crash you want your electric fuel pump to stop pumping gas. Wiring people such as Ron Francis Wiring have these switches. Also, the July/August, 1999, issue of the V-8 Times has an article about using an oil pressure switch as a cutoff. When the engine stops, the oil pressure drops, and the pump stops.The article has all the info you need, including part numbers and wiring diagrams.
woodiewagon46 is offline   Reply With Quote
Old 12-26-2018, 08:10 PM   #19
Ken/Alabama
Ken/Alabama's Avatar
http://www.fifthaveinternetgarage.com/
Got mine here. Good pump with low pressure no regulator needed and unaffected by modern fuels.
