04-19-2016, 07:06 PM | #61 |
Re: Freshly Rebuilt 59AB Help Needed, Near end of my Rope
There's some type issue with the cam journal dimensions and the cam brg clearance numbers??
Can't say exactly why from here, but the journals are way above the high limit and the clearance is also. Something doesn't sound right! If possible I would try to come up with an accurate cam hsg bore number also! This would require a bore gauge. These holes should be 1.9275" (low) to 1.9285" (high). We find them mostly on the high limit almost always! Thanks, Gary in N.Y. P.S. The cam journals should be 1.796" (low) to 1.797" (high)? I have a bunch of OEM cams here and ALL are in that range, One specific on the bench now measures 1.7965" exactly!
http://www.stromberg-bulletin.com/me...berg-equipped/ |
04-19-2016, 07:28 PM | #62 | |
04-19-2016, 08:56 PM | #63 |
Just asking. What was the combination of crank undersize and bearing oversize to make this work? Somebody had to know this was wrong.
Ignorance of the laws of physics does not mean they do not apply to you. |
04-20-2016, 12:15 AM | #64 | |||
Thanks.
http://www.vanpeltsales.com/FH_web/f...ring-specs.htm I don't know whether someone new about the error or not. I bought the package from a friend (and we remain friends). He had the work done by a guy he met at the Portland swap meet who sold him a good (non-cracked) factory relieved block, and some other flathead parts. As they began chatting, the fellow offered to help my friend (my friend was about 79 years old at the time) by assembling the engine for him. My friend, a year later (then 80 years old) decided he wasn't going to be able finish the project and offered it to me. There was certainly no malicious intent on the part of my buddy, he paid for work that he thought had been done well. My block and parts are now at the machine shop. I hope to get them back as soon as possible to resume the project (but I know how busy this one man shop is... he specializes in flatheads and hemi's...along with building land speed cars, and runs his own mid 7 second copy of the '34 Sharp Mooneyham drag coupe). |
04-20-2016, 06:49 AM | #65 |
Glad you found it - a combination that looks like it works, but obviously has the wrong number of oil holes in the wrong places. Putting a 49-53 crank in it is the easiest fix and you might be able to use your existing rod bearings. Welcome to out flathead world - glad you have the interest in working through problems!
04-20-2016, 08:22 AM | #66 |
04-20-2016, 08:55 AM | #67 | |
☆Edit/Correction to the above post: The front oil galley plug is smaller in diameter at the threads than the rear oil galley plug, so the front plug could not be used in the rear. I realized this today when getting a set of front and rear galley plug together to send to a fellow Fordbarner. The above post will be changed to reflect.this correction.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 04-20-2016 at 09:29 PM. Reason: Removed statement on interchangeability of front and rear plugs |
04-20-2016, 08:57 AM | #68 | |
04-20-2016, 09:23 AM | #69 |
You could be loosing oil pressure if the endplay is to much when mixing and regrinding the crank. The endplay for rods is .010 max in 1951 it was changed to .020 and the mains is .002 to .006 worn rod width and regrind side rub could be to much.
05-24-2016, 01:45 PM | #70 |
Ok, I know this thread is over a month old, but for the sake of those that followed it and were very helpful in making suggestions I thought I would give an update of the total of my findings (now that the motor is re-assembled and running smoothly and quietly...as it should).
This motor was an example of some really nice parts assembled poorly (or without the due diligence normally associated with a performance engine build. My mistake was assuming that it had all been carefully checked when the PO (and his engine guy)initially assembled (yet another lesson learned the hard way)! So, I already mentioned the distributor bolts that were too long and hit the cam gear, and of course there was the 59AB crankshaft with the 49-53 rods that created the oiling issue to begin with. Other findings and sources for the cacophony of noise that emanated from this motor...the heads of the bolts that held the flywheel where too tall and made contact with the springs in the clutch plate (bolt heads were cut down on my lathe to correct)...the electrodes on the Autolite 4316 sparkplugs where flattened after having made contact with the valves (replaced with NGK B4L's...that were indexed with washers such that the electrodes were vertical and between the valves)...and finally the original Eddie Meyer heads required significant carving out (and re-polishing) in the combustion chambers as they were contacting a number of pistons and valves (especially as the engine warmed up and parts began expanding, I assume someone back in the day must have milled the heads). Anyway, it's all running as it should now...and I can tidy up the shop after the thrash and prepare to work on upholstery. Thanks all again, Tim |
05-24-2016, 02:46 PM | #71 | |
Best of luck with the motor. Last edited by Tim Ayers; 05-25-2016 at 10:27 AM. |
05-24-2016, 02:47 PM | #72 |
Thanks for the update. I'm glad you have ironed out all the problems.
Mart. |
05-24-2016, 04:21 PM | #73 |
Isn't this stuff fun!!!! You did good!! Congrats!! Pete
05-25-2016, 06:51 AM | #74 |
Nice Job Tim! You stuck with it until the problem was truly identified - that was key to the whole thing. I've seen a lot of folks quit, punt or come to false conclusions on stuff like this - once you find it, it all makes sense. You'll have a good running engine now!
05-25-2016, 10:09 AM | #75 |
Thanks for providing the feedback!
