Old 05-07-2010, 11:07 AM   #1
roccaas
roccaas's Avatar
Default Knocking Rod-pulling the pan
#3 Rod is knocking (hopefully at the big end) when the spark is advanced it sounds like a marching band.
I'm pulling the pan this weekend to look for a loose big end-and hoping there are shims to pull out.
Will also check for roundness of bearing, condition of crank bearing surface, etc.
Any suggestions?
Thanks
roccaas is offline   Reply With Quote
Old 05-07-2010, 12:27 PM   #2
tamagrouchy
tamagrouchy's Avatar
Default Re: Knocking Rod-pulling the pan
You may want to check for carbon on the piston tops too. I just had the head off of my car to fix a burnt valve. It used to make some noise with the spark advanced when the engine was hot, but it went away after cleaning the carbon off the pistons and out of the combustion chamber, i.e. head, top of block etc. Hopefully it's just that. Good luck!
tamagrouchy is offline   Reply With Quote
Old 05-07-2010, 05:17 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
INTERFERENCE FITTING OF BEARINGS
When I purchased my car the engine made a real racket especially after the Breakfast on the beach run. I replaced the timing gear, (it was a real mess) and found this procedure on the web. I have done it on the rods and on the crank.
Because of the weight of the flywheel and the flexibility of the Model A crank,
plastigauge may not be a reliable method of adjusting the bearing clearances.
Here's what I found on the web:
How do you check the clearance on the bearings? It is not QED but can be done if you can lay on your back and work with oil and grit and grime falling in your eyes.
First you gotta drop the pan, let it sit overnight to get all the oil that will fall out to do so. You are still going to get oily. Pull the damn oil pump out and lay it aside. You can shine a flashlight up in there to see which way the tang is oriented to reinstall and with it out there won't be so damn much blood on it to clean off it.
Then I start with the center main. This one requires that the valve cover be taken off as the nut is in side there. The other nut is between 2 and three outside on the other side. Remove the cap being careful to keep the shims on the same side as they came from. Visually inspect the bearing for cracks and places at both the front and back that look as if it has been compressing the babbitt and pushing it forward or to the rear. Bad signs if so. To check the clearance, use a piece of aluminum foil .002 thick. The heavy duty she buys to do heavy-duty things is .002 but the
regular like you cook a baked potato in is .001 so you fold it. You want a piece as long as the cap and about 1/2 wide. Lay this in the cap and with the SHIMS BACK IN THERE put the cap back on and tighten it up. Now you want to see if the motor will turn with the obstruction in place. Stick a 6" punch in one of the balance holes in the crank throw so the pull will be consistent each time you check. You are looking for lockup with the obstruction in there and free without. The shims are increments of .002 or .003 depending on which the rebuild used.
The steel shims are generally in .002 and the brass in .003. Peel 1 increment from one side at a time, one from one side and if that doesn't lock it up then do one from the other side. Yes it tedious; just be glad you didn't buy a space shuttle. Once you get this bearing to lockup then remove the obstruction and replace it and tighten it up again and see if it will rotate. If it won't turn with the 6" punch then put that dame shim back in and run it another 3k.
Do the rear next then the front. The rods adjust exactly the same way. When you finally get a bearing adjusted like you want it put some pre-lube (engine assembly lube) on there before putting it on there for the last time. Torque to whatever you has been using (75 minimum) and go. The rod nuts torque to 40.
To put the pan on there install the oil pump using a 3/8 fine thread bolt in the plug hole in the side of the block to retain the pump while you install the pan. Finger tight as the threads are actually national pipe threads but the bolt will work in there. Get some 5/16 all thread and make yourself some cheaters by cutting 4 pieces 4 or 5 inches long. Screw them into the pan rail and let 'em hang down. Slip the pan over them and start a nut. Then it is a matter of tightening the nuts incrementally in turn and thereby winching the pan up against the spring on the pump.
The gaskets and sealer is a matter of choice but my opinion is that the silicone belongs in the bathroom. I use permatex red personally. When you put it all back together put some of the oil down the dist hole so the valve galley is oiled. It should not have lost any oil but I like to make sure.
Lotta work laying on your back.
Old 05-07-2010, 07:05 PM   #4
roccaas
roccaas's Avatar
Thanks.
I've printed your procedure, do you have the web address?
Old 05-07-2010, 08:26 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
It sure would have been nice if Ford had used studs for the front and center main bolts. With a nut on each end, there would be no need to remove the side cover, or mess with the tight spaces on the other 3 main bolts. I wonder if anyone has done this for their own engine to save time in future bearing adjustments?
Old 05-07-2010, 08:48 PM   #6
82B in WA
I would pull the engine in a heart beat. I hate working on my back under a dripping oil mess and I feel the job is much better done with the engine out of the car. Everything else cal als be double checked for insurance.
82B in WA is offline   Reply With Quote
Old 05-07-2010, 08:51 PM   #7
82B in WA
WOW! I am not so sure I will like this but will tr different posts later and see what I can learn on where to go and what to do.
Old 05-08-2010, 12:01 AM   #8
Mike V. Florida
Originally Posted by roccaas View Post
Thanks.
Sorry, Not any more
Old 05-08-2010, 01:04 PM   #9
Kurt in NJ
Kurt in NJ's Avatar
I had all the babbitt fall out of a rod 20 years ago, when it happened I thought I had driven over a telephone pole , I limped the last 2 miles home( slow with retarded spark), dropped the pan to find no babbitt on #3 rod.
Upon inspection there was no damage to the crank (try that with inserts), I pulled the piston down as far as I could, rotated it , pulled the clip, moved the wristpin out by wiggling the rod and pushing with a heavy bent wire.
I did it as a "patch" repair until I could do a proper repair ---that was 20 years ago and other than for a slightly reduced top speed (balance change, now have more vibration too)the car still runs fine.
