11-12-2017, 01:06 PM | #1 |
Original Cut Out and Gen ??? and Cutout wiring Questions
Hey guys. i have a few questions, are the Cutout and Generator in the picture OEM???? I have noticed on some pictures of other Model A engines on the web that the 2 terminals seem to be reversed, the yellow/black tracer goes to the front side (front of car) of the cutout and the other is the battery terminal. Mine has the yellow/black tracer on the back side (back of car) of the cutout. I'm just trying to get things back to some what normal. i'm guessing that its not OEM.
I also notice there are black and red radiator hoses......is there any specific color/type for my 31????? and can the engine pans be taken out without jeopardizing the oil pan gasket???? thinking about getting them and the coolant pipes powder coated. Thanks in Advance |
11-12-2017, 01:19 PM | #2 |
Re: Original Cut Out and Gen ??? and Cutout wiring Questions
Looks like a reproduction cutout and the Arm should be connected to the output post or lead in the generator and the Bat or battery side to the other.
If you are not sure connect a ohm Meter from the terminals once at a time and the one with 48-49 ohms should be the generator side. The repro cutout ohms may be less than that but that's the original spec. Make sure your not shorting to the case . Reproduction cutouts are junk. Larry Last edited by larrys40; 11-12-2017 at 02:55 PM. |
11-12-2017, 01:29 PM | #3 |
Sooooo..... it looks as though the cutout is on wrong????.....the wires on the pic (according to the cover) are hooked to the battery side and the other side is screwed into the generator..... Could the cap be riveted on backwards by PO?????? im getting ready to order some stuff from Snyders.... do the have a good cutout??
11-12-2017, 01:30 PM | #4 |
Sorry for all the questions thanks in advance.
11-12-2017, 02:30 PM | #5 |
Are there any issues in how its charging that causes you to ask, or is it merely that you have seen pictures of two different configurations?
Your generator has its output post near the front of the generator, and so the yellow/black wire is where it should be, and that is on the output of the cut-out. I see nothing wrong with yours. I do know that there were generators that had the output post in two different configurations. I know because I have one of each. So, for instance, if you had the one where the output was more towards the rear of the generator, the cut-out would be mounted facing the other way and the yellow/black wire would come out the other end. Another way to tell is that the wire should be connected to the post labeled "BATT" , if there is a label. Not all aftermarket cut-outs had good labels. |
11-12-2017, 03:15 PM | #6 |
11-12-2017, 04:00 PM | #7 |
Then you DO need to turn the cut out around. Yellow/black is Batt.
11-12-2017, 04:01 PM | #8 |
So is the Battery terminal in the side of the cut out or is it the one that bolts down to the generator.......And thanks for your input MagicBox....
11-12-2017, 04:34 PM | #9 |
That generator with the output stud at the front was used from October 1928 through
March 1930. The generator with the output stud towards the rear was used from March 1930 through the end of production. It does sound like the cut out is backwards. Bob |
11-12-2017, 05:06 PM | #10 |
Output being the battery???? and this output Battery terminal would have the yellow/black tracer and the horn wires on it???
11-12-2017, 08:00 PM | #11 |
The output of the generator, otherwise labeled "ARM" for armature on the cut-out is the input to the cut-out. The output of the cut-out is the BATT terminal, where the yellow/black goes.
11-12-2017, 08:02 PM | #12 | |
the ARM side of the cutout is connected to. The picture below is the later generator with the output stud towards the rear of the generator. Bob |
11-13-2017, 12:45 AM | #13 | |
11-13-2017, 01:01 AM | #14 | |
11-13-2017, 01:20 AM | #15 |
Reproduction cut outs are ok, in my experience. Mine seemed to be old repro's, from the '60s. If you have any clue about electrics you'll have it sorted, it's all good.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
11-13-2017, 01:48 AM | #16 |
A couple repro cutouts are OK, but the best is the original Ford one. Bert's sells restored original cutouts. Your generator pulley looks a little bit forward from the front plate. Do not powdercoat the inside of the pipe, or it will soon be in the top of the radiator, plugging up the tubes. Ask me how I know.
Looks like you are using a 1930-1 lower coolant pipe on a 1928-9 radiator. Best to use the correct pipe so it joins without a bind. |
11-13-2017, 11:06 AM | #17 | |
Not sure how to take that comment!!!! lol almost sounded like a slam....if so sorry, ill buy every book out their that way you wont be bothered. Ill take my questions somewhere else....I dont want the car judged but want it as correct as it can be. The generator doesn't have a lot of info out there on it, maybe im not doing the right search..............thanks for your next post Mike that was very informative and if that would have been shared at the start this thread would have been dead |
11-13-2017, 11:14 AM | #18 | |
Thanks for your time Last edited by Chevmn56; 11-13-2017 at 11:48 AM. |
11-13-2017, 03:52 PM | #19 | |
Knowing you did not have the book I gave you the answers (I think) to your questions that I got out of that book. Don't be fooled by the word judging in the title. That book is perfect for someone like you that "...want it as correct as it can be.". As an example, you just wanted to know the generator in your car. Did you know there were actually 5 different generators and 5 different cutouts used in the A? There are 18 pages on the electrical system alone (battery cable, starter, starter switch & rod, generator, cutout, terminal box, distributor, spark plugs, coil, ignition cable, all wiring, and electrical connectors). So yea I suggested the purchase of the book. That book and ANY book for that matter cannot always give one the information you need or want. Trying to locate the info, understand what is written, are reasons why forums like this and others exist. Ask any question you want when you want it. Answers like mine pointing you to other sources of information are to help you enlarge your A knowledge so that you may better enjoy your piece of history. Again I apologize if the wording made you think it was an attack but it was rather my attempt to give you more data.
11-13-2017, 08:02 PM | #20 |
I've written everything I can think of on generators and cutouts, but the search function doesn't always find the right answer. Sometimes it's better to search through Google, say search "Wesenberg armature" should bring up anything I wrote about armatures for the Model A. Or search "Marco Tudor top replace" to find information on top replacement. Both Marco and Vince have great websites with a lot of information.
Unfortunately, much information has become useless after photobucket removed all the posted pictures and is now holding them ransom. I now only post straight from my computer, and have started posting information on ford vintage, as well as a lot of other guys, so you now have more sites to choose from. |
11-13-2017, 08:20 PM | #21 |
I always modify my cutouts with a diode. I use black hoses that I repaint the red stripe with the right color red(Rustoleum rusty metal primer.) On the currently available red stripe hoses, the red stripe is too red.
