11-15-2017, 07:45 AM | #41 |
Re: So far, so good on mystery engine
Tom, even with the main like that? Would I try to JB weld it or just put it back in? This is so different than modern bearing stuff I”m used to. I would think the crank would look worse. I will pull the rest apart this morning
11-15-2017, 10:54 AM | #42 | |
Be careful about using JB Weld if you decide to glue that piece back in. JB Weld is thick and may make that thrust piece stick out too far. I'd suggest just holding it in place with a dab of grease, put it back together, and enjoy for many miles. |
11-15-2017, 11:24 AM | #43 |
Thanks 40, I did not sleep over this last night, and I am hopeful I can do just what you suggest! Tearing the rest down today, and hopefully the others look OK.
Greg |
11-15-2017, 02:09 PM | #44 |
Unless I missed something, all of the recomendations have said " OK so long as the clearance is good". So have you measured with micrometers or used plactigage or used aluminum foil measuring methods. Heck even notebook paper will give you an idea of what the clearance is. If you are unsure how, do an advanced search for threads on bearing clearance. By the way, I grew up near Long Beach many years ago and rode my bicycle many times to Ford Parts Obsolete on Willow to get parts for my A projects.
11-16-2017, 08:29 AM | #45 |
Rod clearance is good, I am pulling the crank to clean and inspect and will reassemble to correct specs.
11-16-2017, 09:27 AM | #46 |
