06-12-2017, 04:20 PM | #1 |
Diamond block fuel pump
Well I picked up this diamond block out of a '31 this guy was hot rodding. It's going in my '29 wagon. I have a question about a fuel pump for this engine. It has a block off plate and the eccentric is there on the cam. Who sells a fuel pump for this engine. I've tried searching on line but still not sure what I'm looking for. Any help in this would be great.
I'd go to the far ends of the earth for a GOOD beer. |
06-12-2017, 04:23 PM | #2 |
Re: Diamond block fuel pump
Isn't that a "B"motor and not an "A".
06-12-2017, 04:32 PM | #3 |
Yep, it's a diamond B with a cut oil pan for the flywheel cover.
Unless you are using a low tank or a downdraft carb, you shouldn't need a fuel pump. |
06-12-2017, 04:33 PM | #4 |
Yes it is.
06-12-2017, 04:34 PM | #5 |
Yes I'm doing both. I don't want to run an electric.
06-12-2017, 04:46 PM | #6 |
Charlie Stephens |
06-12-2017, 05:09 PM | #7 |
Volvo b20 fuel pump fits right on you just need to modify the pump lever some, sells on e-bay for about $40.. Cheaper and looks almost the same
06-12-2017, 05:11 PM | #8 |
Thanks Charlie!! I try them.
06-12-2017, 05:14 PM | #9 |
Birch, I use to service write at an independent Volvo garage many moons ago. So B20 is a very familiar thing to me. Do you know what kind of modification must be done to pump?
06-12-2017, 05:33 PM | #10 |
You need to change the angle on the pump lever a bit, it's a simple cut, bend, weld operation. I don't remember how to post pics but if you Google the pumps you will see the differences
11-14-2017, 07:32 PM | #11 |
Does it have this crankshaft?
Short URL: http://smu.gs/14g7eDW |
