01-25-2015, 09:04 AM | #1 |
33/34 Torque Tube & Drive Shaft Difference
Folks,
How can you tell the difference on the 33/34 Torque Tube & Drive Shaft. I know they differ from 4-8 Cylinder. My question is: 1. Is there an obvious external difference or is measuring the only way. 2. What are the measurements for the two different shafts and tubes. |
01-25-2015, 10:48 AM | #2 |
Re: 33/34 Torque Tube & Drive Shaft Difference
"For 1933-1934 Fords, regardless of what engine they had, 4 or V8, they were both built on exactly the same chassis & wheelbase. The difference in length is only in the Drive Shafts, to accommodate for the longer 4 cylinder engines. The length of the Drive shaft in the V-8 = 60 5/32” while the Drive shaft in the 4 cylinder = 58 7/16” It follows that the Tube on the 4 cylinder was shorter by same amount." |
