08-10-2019, 03:17 PM | #1 |
needed 6 volt battery charger
Harbor Freight once sold a 6 volt battery charge that worked great charging optima 6 volt batteries. My 6 volt charge no longer works....Not so great.
Who sells a decent charger? |
08-10-2019, 03:26 PM | #2 |
Re: needed 6 volt battery charger
HOME DEPOT > https://www.homedepot.com/p/BLACK-DE...BM3B/202710992
BLACK+DECKER Model # BM3B $23.05 1.5 Amp Battery Charger/Maintainer compatible with 6- and 12-Volt AGM, GEL and WET automotive/marine batteries
$15.18 at AMAZON > https://www.amazon.com/BLACK-DECKER-.../dp/B0051D3MP6 Product description The BLACK+DECKER BM3B high frequency battery charger and maintainer is used to keep batteries in stored vehicles and battery applications at optimal capacity during the off season. Charges 6 volt and 12 volt AGM, GEL and WET batteries in RVs, specialty vehicles, antique and classic cars, marine deep cycle batteries, motorcycles, lawn mowers, ATVs, snowmobiles, and personal watercrafts. Slide the voltage selector switch to either 6V or 12V depending upon the battery you are charging. Connect the battery charger and maintainer with the included battery clips or battery ring terminals. Charging automatically stops when battery is fully charged or topped off and switches to float mode monitoring to maintain charge. Built-in circuit protection guards against overcharging, reverse polarity, or short circuit and is ETL certified for performance and safety. The BLACK+DECKER BM3B battery charger and maintainer has a built-in mounting bracket for convenient placement and includes a limited 1 year manufacturer warranty.
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 08-10-2019 at 04:54 PM. |
08-10-2019, 05:27 PM | #3 |
Check out the chargers at "no.co". Four letters with a dot in the middle. Also available on amazon. I have two for maintainers, but also charge with them.
08-10-2019, 05:38 PM | #4 |
No Co seems expensive. Check out Battery Tenders on E Bay.
08-10-2019, 07:42 PM | #5 |
Frank, I bought this one several years ago it does 6 and 12V. Battery extender SC4 model BE01250.
Has a rate selector 3A maintainer or 15A rapid charge, battery type standard, AGM or gel. If your not paying attention it even has a revered clamp indicator. I think I bought it @ O'Reilly auto. |
08-11-2019, 07:06 AM | #6 |
08-11-2019, 11:57 AM | #7 |
Wal-Mart has a good charger. 6 and 12 volt with a battery maintainer and will charge Optimo batteries, Was originally a Shumacher brand but now has a Wal-mart label.
08-11-2019, 11:12 PM | #8 |
Get a Schumacher charger for basic all around charging. They are cheap. Good charger. If lucky they can be found at a garage sale or auction.
optima's need to be charged not tendered other then running (gen). Charge them twice a yr, 10-14 yrs, 2 batteries. Great battery. A optima rep has been on there and has said treat it like a battery. It does not not to be tended. Last edited by Tinker; 08-12-2019 at 02:06 AM. |
08-12-2019, 01:29 AM | #9 |
Save a battery charger maintainer. Really good unit. not only charges but maintains. Also this unit can bring batteries back from the dead by cleaning the plates. Can be got in 6v 12 v and 24. I've got a 6 and also a 12v and use them all the time
US unit too https://www.youtube.com/watch?v=E1MCYd0Ket0 GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
08-12-2019, 02:46 PM | #10 |
We use the "Battery Tender" that is adjustable for 6 or 12 volts as a maintenance charger. They are readily available. We use them for both conventional lead-acid batters, and for the Optima, as well.
08-12-2019, 03:12 PM | #11 | |
analyzers. Schumacher for regular chargers. I have both Noco Genius and Battery Tender Jr for maintainers. I'm doing a "trial" on those two to see which one is better on Optimas right now. |
08-13-2019, 07:18 PM | #12 |
HF has a small unit that does 6 and 12 and AGM, GEL, and STD.
It was less than 25 with a coupon. Works great. |
08-14-2019, 11:34 AM | #13 |
search on 6/12 volt on google, they are out there. Try Tractor Supply. I have a 6volt battery tender and a 6/12 craftsman that I bought when sears was still going.
Short URL: http://smu.gs/14g7eDW |
08-14-2019, 07:45 PM | #14 |
https://www.fordbarn.com/forum/showt...08#post1766908
post 13 on the thread. I'm sure if you have questions they can be asked directly by pm, concerning the optima battery. Great battery in my thinking. |
