Old 07-04-2019, 06:35 AM   #1
Fatboy Tim
Default Flathead front end noise
Looking for ideas here.
Rebuilt 59a, 3 bolt Mallory crab distributor. There is a clicking from the front end and seems to be from the timing cover / dissy. I've set the lash on the Johnsons lifters and all good.
Could be cam button hitting locking tabs on cam or any other suggestions?
Thanks in advance for any suggestions.
Fatboy Tim is offline   Reply With Quote
Old 07-04-2019, 10:46 AM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: Flathead front end noise
Make sure the rotor isn’t making contact with the electrodes in the cap on that Mallory.
Old 07-04-2019, 10:59 AM   #3
Willit Stop
Willit Stop's Avatar
I haven't been around any 59a's. But if they're anything like my 21 studder and have a vacuum brake in the distributor, you might try disconnecting and plugging the vac hose and see if the noise goes away. It COULD be that little piston bouncing. If so, grease the piston and try again. It worked for me.
Willit Stop is offline   Reply With Quote
Old 07-04-2019, 11:15 AM   #4
Ken/Alabama
Don’t think his Mallory is gonna have the vacuum brake.
Old 07-04-2019, 11:17 AM   #5
Willit Stop
OK... I guess I missed that part.
Old 07-04-2019, 12:36 PM   #6
john in illinois
john in illinois's Avatar
A bent crankshaft pulley can cause a click as the belt goes around. we straightened one and it still clicked.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 07-04-2019, 12:39 PM   #7
JWL
Check the length of the 3 bolts which attach the dist. to front cover.
JWL is offline   Reply With Quote
Old 07-04-2019, 02:33 PM   #8
Fatboy Tim
Good advice trying that now thanks
