Old 12-07-2017, 08:51 AM   #1
barkleydave
barkleydave's Avatar
Default oil leak at center block bearing bolt
Have oil leaking bearing center main bearing bolt. Any fixes without tearing it down. Sealants etc. It is not a huge leak just messy one.
Thanks
barkleydave is offline   Reply With Quote
Old 12-07-2017, 10:18 AM   #2
redmodelt
redmodelt's Avatar
Default Re: oil leak at center block bearing bolt
You could try; Clean the area around the nut. Hook a vacuum cleaner hose up to the oil fill spout. With the vacuum on, work sealer around the base of the nut. With luck the vacuum will pull sealer into and voids. Other then that, it's drop the pan to fix.
This is a fix done by Model T people, and the T engine is a lot less air tight.
Old 12-07-2017, 11:07 AM   #3
burner31
burner31's Avatar
I've never heard of this method...But it's brilliant!
Them "old timer's" sure had the "American can do" attitude
Keith
Shawnee OK
'31 SW 160-B
Old 12-07-2017, 11:19 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Remember, it's NOT a pressure leak, it's just from SPLASH & CAPILLARY wicking.
Bill Sealerguy
"THE ASSISTANT GURU OF STUFF"
