Old 01-14-2020, 05:56 PM   #1
Mulletwagon
Mulletwagon's Avatar
Default Tire Pressure
Anyone have a recommended min/max tire pressure for a 31 Tudor ?
Mulletwagon is offline   Reply With Quote
Old 01-14-2020, 06:46 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Tire Pressure
35#. When they get down to 30# just fill em back up.
Old 01-14-2020, 06:52 PM   #3
Gary WA
Gary WA's Avatar
As per tire specialists- they say to run at about 37-38-thats what I run!
www.whidbeymodelaclub.com
Old 01-14-2020, 10:04 PM   #4
eagle
eagle's Avatar
This has been discussed at great lengths, but like oil, everyone has 3 opinions. I like to run them harder, over 40 lbs. Improves handling and tires wear more evenly. Of course I have a 29 so not completely applicable to your situation. You can see in my avatar there isn't the typical tire squish.
Old 01-15-2020, 08:38 AM   #5
rocket1
Tire pressure is sometimes printed on the sidewall,I inflate to 35 psi.
rocket1 is offline   Reply With Quote
Old 01-15-2020, 09:00 AM   #6
Mulletwagon
Thanks guys. My tires did not look too low but I was surprised they were only aired up to about 15 psi ! Just not that obvious when they are low. Checked and confirmed max pressure was not posted on the side walls.
Old 01-15-2020, 09:02 AM   #7
jwilliams81
jwilliams81's Avatar
The Ford Model A Instructions manual that came with the car when it was new says 35 psi.
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 01-15-2020, 11:36 AM   #8
Tom in SW VA
Tom in SW VA's Avatar
35 psi
Tom in SW VA is offline   Reply With Quote
Old 01-15-2020, 12:25 PM   #9
DBrer
I'm getting good tire wear at 35 psi.
DBrer is offline   Reply With Quote
Old 01-15-2020, 08:00 PM   #10
Big hammer
Check the pressure often!
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 01-16-2020, 02:03 AM   #11
cpf240
cpf240's Avatar
Most of the time, that number is Max pressure, and it should indicate if that is the case. Max is what the tire can handle, and shouldn’t be assumed to be correct for the vehicle it is currently attached to.
I always verify with the factory tag on the vehicle or the owners manual for proper tire pressure.
cpf240 is offline   Reply With Quote
Old 01-18-2020, 03:05 PM   #12
bdtutton
Everything I read says 35 psi is the target pressure for 19 inch tires....and my car drives the best when the tires are kept around 35psi.
bdtutton is offline   Reply With Quote
Old 01-18-2020, 08:43 PM   #13
whirnot
whirnot's Avatar
Ford said 35# for all cars except Station Wagons and pickups, which were 40#
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 01-19-2020, 09:34 PM   #14
jm29henry
jm29henry's Avatar
How could anyone dispute j Williams 81
jm29henry is offline   Reply With Quote
