Old 12-10-2019, 12:37 AM   #1
cabrioletgalaxie
Exclamation 1947 clock not working
The clock in my '47 is not working. Before I take it out and screw it up I would like some advise as to the safest and best way to start. Or is there a 'clock guy' I should consider sending it too?
I have not checked any wiring to it but know that is probably the best place to begin.
Suggestions on how to proceed are appreciated. Thanks.
cabrioletgalaxie is offline   Reply With Quote
Old 12-10-2019, 07:16 AM   #2
tubman
tubman's Avatar
Default Re: 1947 clock not working
I have an electric-wind clock in my '51 Ford which was not working. I took to a local clock repairman who had fixed my Grandfather clock for me a couple of years previously. He inspected it and found it just needed a good cleaning (which he did for $20). I got it back a couple of days later. That was a couple of years ago and it's still working. The only problem is that I can't get it to keep time closer than about a minute or two a day, but I guess that's just the nature of the beast.
I am sure there are people out there you can send it too, but I knew this guy and decided to save time and shipping. After all, a clock is a clock.
Old 12-10-2019, 08:03 AM   #3
fordwife
Look in Hemmings. There are several people that offer this service.
fordwife is offline   Reply With Quote
Old 12-10-2019, 09:06 AM   #4
RKS.PA
RKS.PA's Avatar
The clock is my '47 wasn't working either, and as Tubman said above, sometimes all that is needed is a good cleaning. Mine is a windup that only runs for 24 hours.
I took it out, cleaned it carefully with WD-40 and then got some clock oil and special applicators from Amazon. Maybe I was lucky, but it works perfectly now.
Even though I don't rely on it, I just wanted it to work properly!!
RKS.PA is offline   Reply With Quote
Old 12-10-2019, 12:42 PM   #5
34pickup
34pickup's Avatar
Will they work on 12volts without a resistor to drop the voltage?
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 12-10-2019, 01:12 PM   #6
cabrioletgalaxie
I am not sure if mine is a windup or electric. It does have a wire going to it but I suppose that is just for the light in it. I did try winding it but it didn't change anything.
Finding a local clock repair guy makes sense. I'll check around to see what I can find.
Old 12-10-2019, 01:21 PM   #7
oldford2
oldford2's Avatar
The clock in our 46 was not working so I sent it to Jerry Maquire for a repair. 7 years ago. quick turnaround and reasonable. Still going strong. Ours has 2 wires to the clock, one for the light and 1 for the winding mechanism.
Check out his website
www.clockwks.com
And give him a call.
John
oldford2 is offline   Reply With Quote
Old 12-10-2019, 02:03 PM   #8
tubman
tubman's Avatar
Might not be the same, but mine (electric-wind) had two wires going to it. One without a fuse for the light; another with an inline fuse for power.
Old 12-10-2019, 02:32 PM   #9
RKS.PA
RKS.PA's Avatar
According to the 1941-1948 Ford Book, the electric wound clock was an option at an additional charge beginning in 1946, and the manually wound clock was standard.
Old 12-10-2019, 04:21 PM   #10
tubman
tubman's Avatar
Probably; I would imagine that a properly-sized resistor would have to be used. I'm just guessing on this, but if you are interested, I could ask my partner who is an EE and knows about such stuff. We should probably have the rated amperage of the winding mechanism.
Old 12-10-2019, 07:13 PM   #11
34pickup
34pickup's Avatar
I guess I need to check and see if its electric first, I just assumed it was.
Matt 24:36-41
Old 12-10-2019, 11:54 PM   #12
cabrioletgalaxie
Thanks for the Clock Works contact. I just filled out a quote request. I also found the clock to be electric. One wire to the light in the clock, and a second wire to the lower part of the clock, and yet a third wire forked off the power wire. Looks OEM but was just hanging there and un attached to anything. I cannot tell from the wiring diagram what that other "hot" lead wire is for. It is yellow/black. I don't like it hanging loose under the dash. Any thought of what it should attach to?
Old 12-11-2019, 05:01 AM   #13
FortyNiner
FortyNiner's Avatar
Originally, the clock was on the same circuit as the pillar courtesy lights. This circuit was alays hot. The 'fork' might just be the break in the wire run for those lights.
Old 12-12-2019, 12:50 PM   #14
jetmek
take the back off and clean the points with an ignition point file that's usually all it takes
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 12-12-2019, 03:10 PM   #15
51 MERC-CT
51 MERC-CT's Avatar
The clock probably could use a cleaning but one of the reasons that these electric impulse wound clocks quit is because of the arc residue on the points that needs to be removed.
It may be worth a try.
Old 12-12-2019, 04:56 PM   #16
51woodie
51woodie's Avatar
51 Merc. That was what was wrong with the clock I my '46 Super Deluxe. It worked after I carefully cleaned the contacts with a point file (old school tool). But I found there was very little pressure on the point when closed, so I bent the arm holding the top contact blade a bit to add some pressure when the points are in contact.
51woodie is offline   Reply With Quote
Old 12-12-2019, 08:53 PM   #17
cabrioletgalaxie
Thanks buys for this info. I will get the clock out and check this out. It usually is something simple.
