01-21-2020, 09:34 AM | #1 |
Front Main Spring
My new barn fine ‘28 Sport Coupe A toy.
The first time, I have seen “boot wraps” on each side of the front spring. What are their purpose? They look some what original - older and dried out - each about 10 “ in length. Thanks for your thoughts Dave Last edited by dlfrisch; 01-21-2020 at 09:40 AM. Reason: Grammar - their ...... dried out |
01-21-2020, 09:38 AM | #2 |
Re: Front Main Spring
Boots keep the grease/oil inside and the dust and road grime outside. Ford did offer them as an original accessory. I think the ones from Ford were leather or pleather. I wish my car had them. I'm going to get a set when I rebuild the front end.
01-21-2020, 09:42 AM | #3 |
spring covers can be aftermarket or original ford --on page 316 of the service bulletins there are pictures and installation instructions
01-21-2020, 09:43 AM | #4 |
Thanks - I haven’t noticed them listed at the suppliers.
01-21-2020, 09:52 AM | #5 |
These are the covers I got when I cleaned and re-lubed both springs. Worked pretty well, fit was good. I kinda went overboard soaking the felt in oil, so I had oil puddles behind the wheel hubs for a couple of weeks afterward.
https://www.snydersantiqueauto.com/P...RING-COVER-SET |
01-21-2020, 09:56 AM | #6 |
1931 Murray Town Sedan. Black body with Apple Green pin stripe. 1923 Model T Touring with electric start. Low radiator Cincinnati, Ohio |
01-21-2020, 12:04 PM | #7 |
I just used motor oil on mine, any suggestions on weight of oil when I renew oil. No squeaks and coupe rides great.
01-21-2020, 05:19 PM | #8 |
01-21-2020, 05:41 PM | #9 |
I think you could literally use oil straight out of the drain plug if you wanted.
01-23-2020, 01:37 AM | #10 |
I also have a 1959 Triumph TR3 and the original service manual states use the drain oil after each oil change to paint the leaf springs. I don't think the meant using all five quarts.
01-23-2020, 03:15 AM | #11 |
dlfrisch, when I was going to create an advertisement assignment I found out this topic. This one is useful for me .
alexiskai I was in a similar situation but approximately 2-3 weeks Last edited by AdrianLomezzo; 01-23-2020 at 03:23 AM. |
01-23-2020, 03:09 AM | #12 |
Using any type of liquid (oil) or paste (grease) type lube on leaf springs is bad practice. Even with spring covers or wrapping with vinyl tape, dirt will get in and create abrasive grit that both increases spring rate and accellerates wear.
Two good methods or lubing springs are Teflon strip between leaves or polishing the leaves and painting them with MOLYKOTE or SLIPLATE. |
01-23-2020, 11:08 AM | #13 |
See pages 268. and 316 in the Ford Service Bulletins.
The Master Cylinder Enjoying life at the beach in SoCal... |
