04-16-2019, 10:46 AM | #21 |
Re: Rebuilt engine over heating
Perhaps do the re-torque and see what happens. My motor rebuilder told me to re-torque at 50 miles, 100 miles, 200 miles , and 500 miles, if torque has stabilized at 500 miles re-torque once a year. I plan re-torque every fall to prevent possibility of coolant leak during storage.
Then do a compression test to confirm the head/gasket are OK. If you still overheat - NAPA has a $50 Block Test Kit that measures for exhaust gas in your coolant. Very simple to do, and has enough test fluid to do many tests. Or perhaps take it to a local mechanic or radiator shop and have it done. Unknowingly I had a 2 row core radiator that caused overheating - not enough capacity. Have been told the only good 2 row is a Brassworks. 3 or 4 row is recommended. Last bit of info - My motor rebuilder told me in the hundreds of motors rebuilt he has had 2 that he had to redo They were too tight and caused over heating. - I hope this is not what you have. |
04-16-2019, 11:13 AM | #22 | |
04-16-2019, 11:41 AM | #23 | |
Premium Head Gasket? If you are using the siliconed gasket, I have seen discussions from people having problems with them. From my memory, it was not determined if it is not a good gasket, or if there are special procedures to be followed at install that are not being strictly adhered to. I think I saw one or 2 people insisted they followed the instructions that came with the gasket, and the gasket failed in a very short time. With them doing it at home, perhaps possible the head and block were not ground perfectly and this gasket is not tolerant? Do not know. Either way they have a bad rap, and people seem to shy away from using them. Last edited by 30 Closed Cab PU; 04-16-2019 at 11:42 AM. Reason: typo |
04-16-2019, 08:44 PM | #24 |
What do you mean by "new radiator"? Is it a brand new recored radiator or another used radiator? If its a used radiator it could be plugged.
