04-16-2013, 06:43 PM | #1 |
LED Turn signals
Looking for some recommendations on the best LED turn signal/brake light system to put on my 29 Tudor. I will not be using it as a daily driver, but plan on using it frequently. I would like a complete system that works off the +Gnd 6V if possible.
Thanks to all and God Bless America!! |
04-16-2013, 07:05 PM | #2 |
Re: LED Turn signals
LogoLites is what I use. I've been very satisfied. You can Google them.
Larry Seemann |
04-16-2013, 07:09 PM | #3 |
Highly recommend the following:
http://www.logolites.com/led/turn/signals/ And add the following to REALLY grab the attention of tailgaters: http://www.jandlenterprise.com/products/products.htm Both work great on 6V+ stock systems. I mounted the turn signal control box behind the driver's side kick panel, so all you see is two tiny buttons sticking out of half-dime sized holes. Last edited by John Butts in CT; 04-16-2013 at 07:30 PM. Reason: Typo |
04-16-2013, 07:14 PM | #4 |
Brattons' since 2005.
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die! |
04-16-2013, 09:02 PM | #5 |
I am extremely pleased with the LED panel built into the original 1931 taillite drum.
Its as bright as that of a modern car, though I have supplemented it with a Third Brakelite, setup too. I have gone ALL RED since Its easire to not try to teach the world about red and amber taillites. I use a $40 Signal Stat 900 Directionals knockoff style switch which has worked perfectly for 10 years. |
04-16-2013, 10:25 PM | #6 |
They make a chirping sound when flashing. Good people.
Mike Stitt "A business that make nothing but money is a poor business." -Henry Ford |
04-17-2013, 05:27 AM | #7 |
Logolites as well. Bright and I like the 4 way flasher. Great people to deal with.
Dave A Jamieson Portland, ON Canada 1928 Tudor |
04-17-2013, 06:42 AM | #8 |
Dal. The logo lites work great at night, only problem is day time.People are not going to see them hardly at all from the rear. I 've had logo's since 2001, I have them on 31 tudor. 3rd brake lite in window really is bright says STOP, best money I ever spent was the 3rd light. HAVE FUN MODELatony LAFAYETTE,la
04-17-2013, 03:57 PM | #9 |
I too use the signal stat with the LED brake lights and the original bulbs in the cowl lights, works great 6V pos ground. The high 3rd brake light by J & L Enterprises is the BEST. It really gets the attention of the texters and cell phone crowd, which seems to be most of the drivers today. Its called the BrakeLighter and is made in America 860 916 3582 to order one, it might save your life.
Martin Cooke Higganum, CT |
04-17-2013, 05:24 PM | #10 |
In my turn signal setup, I used the United Pacific red LED taillights, a Brakelighter for the third brakelight, and modified Logo lights for the front turn signals. My truck is 6 volt positive ground and the rear LEDs and third brakelight are REALLY bright. The front turn signals are also "parking lights" and are on in any of the three positions of the steering wheel light switch. The back lights are turn signals, brake lights and "parking lights" and everything is wired throught a homemade control box with two 4-pole relays. The turn signals work off a small "center off" micro-switch and a second micro-switch controls the 4-way flashers.
AL in NY |
