Old 10-15-2019, 06:21 PM   #1
doug.nichols
doug.nichols's Avatar
Default Borg Warner Torque Tube Stuck
Having no luck detaching old BW overdrive rear torque tube from banjo. All bolts are out but there is no movement of the tube, even with wood block and hammer. I notice there are extra holes in the BW rear torque tube flange, and I am wondering if I need to run some bolts into those holes to pry the flange loose. Feels like the drive shaft might be integral to the tube in some way, unlike stock Modal A setup. Picture attached.
doug.nichols is offline   Reply With Quote
Old 10-15-2019, 07:27 PM   #2
Bob C
Default Re: Borg Warner Torque Tube Stuck
Have you seen Tom Endy's article? http://www.santaanitaas.org/wp-conte...ner-Repair.pdf
Bob
Old 10-15-2019, 07:38 PM   #3
doug.nichols
Yes. Unfortunately I could not find information about the connection of the rear torque tube to the banjo....
Old 10-16-2019, 08:34 PM   #4
doug.nichols
Problem solved. Hydraulic jack and wood block broke it loose. Strange, large hammer and wood block would not budge it. Surprised to see chains inside BW overdrive. Really?
Thread Tools
Display Modes
