09-12-2016, 07:09 AM | #1 |
46 Ford 1.5 ton
Sunday was a beautiful day so we thought we would pull the old truck out of the garage. This is the first time in 20 years that it has moved under its own power. Then we just couldn't resist driving around the block a time or 2. What a thrill to experience all the familiar sounds and smells these trucks have. Still have some items to finish but the cab and chassis is almost complete. Next phase is to install a Gar Wood dump body from my parts truck.
09-12-2016, 07:18 AM | #2 |
Re: 46 Ford 1.5 ton
Nice truck, my dad bought a new one in 46, had a dump box on it. Good luck with it
09-12-2016, 08:06 AM | #3 |
Re: 46 Ford 1.5 ton
Great looking truck, just something about those big trucks, enjoy.
09-12-2016, 09:56 AM | #4 |
Re: 46 Ford 1.5 ton
AHHH, double clutching, gear grinding, smokey doping smell--it don't get any better than that!! great looking truck!
09-12-2016, 11:57 AM | #5 |
Re: 46 Ford 1.5 ton
Joe
Fine looking truck. Bruce
Works good Lasts long time |
09-12-2016, 12:20 PM | #6 |
Re: 46 Ford 1.5 ton
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
09-12-2016, 08:33 PM | #7 |
Re: 46 Ford 1.5 ton
09-12-2016, 08:37 PM | #8 |
Re: 46 Ford 1.5 ton
06-23-2019, 08:44 AM | #9 |
Re: 46 Ford 1.5 ton
[ATTACH]IMG_0773.jpg[/ATTACH]
Finally finished the dump bed and got it installed on the truck. I'm really pleased with the way the bed looks on the truck and it makes it ride a little better. Now for some mud flaps and marker lights. |
06-23-2019, 08:58 AM | #10 |
Re: 46 Ford 1.5 ton
06-23-2019, 09:22 AM | #11 |
Re: 46 Ford 1.5 ton
06-23-2019, 04:35 PM | #12 |
Re: 46 Ford 1.5 ton
Nice truck!!!.....that’s some serious rubber on the back of it.....I have two dump bodies like that if any ones looking......Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
06-23-2019, 07:52 PM | #13 |
Re: 46 Ford 1.5 ton
Very cool truck !!! I may be slightly bias
06-23-2019, 08:44 PM | #14 |
Re: 46 Ford 1.5 ton
Thanks guys! I think the 8.25x20's in the rear and the 7.50x20's front give the truck a nice stance.
Mark, are the dump bodies you have made by Gar Wood and do you have the hydraulic cylinders? Mine is leaking around the piston with the bed in the down position. M-H, nice truck! M-H trucks are way cool. |
06-23-2019, 09:20 PM | #15 |
Re: 46 Ford 1.5 ton
Have you tried repacking the rope seal?
06-24-2019, 06:42 AM | #16 |
Re: 46 Ford 1.5 ton
06-24-2019, 09:02 PM | #17 |
Re: 46 Ford 1.5 ton
I did the two input shafts, but not the ram itself. I almost think they are meant to leak just a little.
06-24-2019, 09:12 PM | #18 |
Re: 46 Ford 1.5 ton
post a picture of the end of the cylinder, there are two types of packing for these cylinders, one is chevron and one is rope, which has been replaced with a Teflon packing. leaking in the down position could be wear on the cylinder--do they leak when raised?
06-24-2019, 10:57 PM | #19 | |
Re: 46 Ford 1.5 ton
I’ll get a better pic of the end of the hyd cylinder. There is a collar around the piston secured with 2 studs and nuts. I assume this is where the packing is. |
06-24-2019, 11:09 PM | #20 |
Re: 46 Ford 1.5 ton
