08-17-2018, 12:41 PM | #1 |
seat belt fastern dimensions
Hi All,
Getting to the point of installing seat belts in my 30 Townsedan. I have 7/16x3 bolts so far which I gleaned from Les Andrews book. But what bolts go in the back-size wise? I may even have to get longer bolts for the front depending on where and how I mount the front belts. Mike
08-18-2018, 10:47 AM | #2 |
Re: seat belt fastern dimensions
Good info in the Restorer-May-Jun 1993pg26-
www.whidbeymodelaclub.com |
08-18-2018, 11:19 AM | #3 |
Bolts should be good ones, grade 5 or 8. There should be a large flat washer and a lock washer on the other end of the bolts, they usually come with the seat belts.
08-18-2018, 12:21 PM | #4 |
When I installed belts in my '32 back in'61 I used 6" square 3/8 thick steel plates under the floor, NOT a flat washer, FWIW
Paul in CT |
08-19-2018, 10:19 AM | #5 |
Plates like 1931 flamingo used are especially needed if the bolt will be going thru wood. On one of my cars I installed a 2"x2" angle iron inside the frame and bolted the belts to that. All body styles are not the same.
08-20-2018, 04:28 AM | #6 |
08-20-2018, 09:24 AM | #7 |
08-20-2018, 10:44 PM | #8 |
Proof load tensile strength on a 3/8 grade 5 bolt is 6600 lbs, grade 8 is 9300 lbs.
