Old 07-27-2018, 07:52 PM   #1
woofa.express
woofa.express's Avatar
Default radiator filters
I am about to put new radiators in each of my 28's. The block is thought to be reasonably clean however I don't want trash entering these new investments.
What are your thoughts people on radiator filters.
Thankyou in anticipation for your responses. g
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 07-27-2018, 09:01 PM   #2
eagle
eagle's Avatar
Default Re: radiator filters
Great idea, clean often though
Old 07-27-2018, 09:10 PM   #3
dave in australia
Use a nylon stocking. Cut the bottom part of the leg off and place the open end over the upper water neck inside the hose, and the toe about equal to the top part of the upper hose. Been using them for years.
dave in australia is offline   Reply With Quote
Old 07-28-2018, 01:11 AM   #4
Hoogah
Hoogah's Avatar
This is what I got when I picked up my recored radiator yesterday.
File Type: jpg 4DEA2542-F24E-4B94-9449-CB82C94F1D1B.jpg (34.4 KB, 279 views)
Hoogah is offline   Reply With Quote
Old 07-28-2018, 03:37 AM   #5
old31
I bought this at Amazon and installed two screens and gave 1 to my wife. They come 2 per pack.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
old31 is offline   Reply With Quote
Old 07-28-2018, 11:54 AM   #6
1930artdeco
1930artdeco's Avatar
I am using the Gano filter. So far working great at keeping the crud out.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 10-21-2018, 04:23 AM   #7
woofa.express
thankyou all for your input. I used the Gano type and in the first run of about 900 miles I pulled a good tablespoon from the filter. This was otherwise going to lodge in my new radiators. I liked the tea strainer too but was unable to acquire a two inch one locally.
thanks again all. gary
I know many things,
Old 10-21-2018, 04:24 AM   #8
woofa.express
Yes I liked that idea too. gary
I know many things,
Old 10-21-2018, 09:56 AM   #9
WHN
Just be very careful with a filter on the cooling system.
Please remember, Model A’s are “syphon flow” aided by a water pump for higher speed assistance. Flow is about 36 to 38 gpm. Modern cars are 100 gpm plus.
If your filter starts to restrict flow, you could be in trouble fast.
If you have completely cleaned out you block? That along with your new radiator could be all you need. Enjoy.
Old 10-21-2018, 10:06 AM   #10
harryc
hcc
harryc is offline   Reply With Quote
Old 10-21-2018, 10:25 AM   #11
harryc
hcc
Old 10-22-2018, 11:13 AM   #12
woofa.express
Thankyou for the reply. The head and block were cleaned with the head off to fit a new head gasket. Not like a rebuild when cleaning is easier so the cleaning wasn't squeaky clean. I would think very little rust will be loose in system now. The temp didn't get hot by1, the temp gauge on the cap and 2, one of those infra red temp readers, the point and read type. Don't recall the correct name for them. cheers, gary
I know many things,
Old 10-22-2018, 11:16 AM   #13
woofa.express
Originally Posted by harryc View Post
hcc
Hello Harry. I'm not familiar with the abbreviation hcc?
I know many things,
Old 10-22-2018, 12:00 PM   #14
100IH
May Be His Initials.?
100IH is offline   Reply With Quote
Old 10-22-2018, 12:21 PM   #15
30 Closed Cab PU
Here are a couple of additional threads, If you do a search, probably a lot more threads.
https://www.fordbarn.com/forum/showt...ighlight=tefba
Old 10-22-2018, 04:32 PM   #16
woofa.express
yeh, probably. Maybe he's like me and finds difficulty in understanding just how to use these forum programs.?
Do have another go hcc. cheers, gary
I know many things,
Old 08-18-2019, 09:42 PM   #17
woofa.express
yes this fitted snuggly. a good idea but one would need to check it frequently to ensure it was clogged and thus restricting flow. I think a temp gauge would need to be fitted to operate in conjunction. thankyou old 31.
I know many things,
Old 08-18-2019, 11:43 PM   #18
Mike V. Florida
Mike V. Florida's Avatar
Like he said, check it often!!! Once all clear, you can remove it.
Old 08-19-2019, 09:47 AM   #19
37 Coupe
37 Coupe's Avatar
Search Tefba,a filter made in Australia and on Ebay sometime.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 08-20-2019, 09:08 AM   #20
30 Closed Cab PU
A review of mine on the Tefba filter.
https://www.fordbarn.com/forum/showt...ighlight=Tefba
Addition info/update - I called V12 multiple times about the magnet, was promised it, and never received it. Have since converted to the Gano. I just feel it is handier to check it visually every time I am under the hood.
