Old 11-20-2017, 01:59 PM   #1
Bill Goddard
Bill Goddard's Avatar
Default leaks around differential bolts
I have leaks from under the heads of 5 bolts in the lower half of the bolt circle of my differential pumpkin. Is there a fix for these leaks. They are as tight as I dare make them. Bill G
Bill Goddard is offline   Reply With Quote
Old 11-20-2017, 02:12 PM   #2
Fullraceflathead
Fullraceflathead's Avatar
Default Re: leaks around differential bolts
Someone may have chased them with a tap and removed some of the original metal.
Originally they were a slightly undersize thread to prevent leakage.
If it were mine I'd remove them one at a time and put some sealer on the threads like Silicone. Then re Torgue them and wipe away any leftover silicone sealant.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 11-20-2017, 03:17 PM   #3
Tom Endy
Tom Endy's Avatar
They should be torqued to 35 ft. lbs. What you can do is drain the oil and then remove each bolt one at a time and coat the threads with Indian Head gasket cement and reinstall.
Tom Endy
Tom Endy is online now   Reply With Quote
Old 11-20-2017, 03:35 PM   #4
Synchro909
Synchro909's Avatar
Tom Endy
Would Permatex No 3 work?
Old 11-20-2017, 03:56 PM   #5
wrndln
What I did to stop leaks on the bottom bolts of a 7 tooth steering column was to take some cotton thread and wrap it around just under the head. It would depend on how thick the tread is for how many turns to make, but it took a number of turns. I tried all kinds of things before the thread deal and nothing stopped the slow leak. I don't know why the same thing wouldn't work for the banjo.
Rusty Nelson
Old 11-20-2017, 05:13 PM   #6
Synchro909
Synchro909's Avatar
Rusty Nelson
Yeh, that would probably work. The cotton might expand as it absorbed the oil and seal the thread just like hemp was used to seal threaded joints in galvanised water pipes.
Old 11-20-2017, 06:46 PM   #7
glenn in camino
glenn in camino's Avatar
Do you nave lock washers under the bolts? That might be why they're leaking.
Old 11-20-2017, 10:15 PM   #8
J Franklin
J Franklin's Avatar
I use Locktite blue.
Old 11-20-2017, 11:31 PM   #9
chiliman
Yeah I have heard thread works for issue
chiliman is offline   Reply With Quote
Old 11-21-2017, 12:14 AM   #10
w.michael
w.michael's Avatar
I used Indian Head shellac just as Tom Endy suggested. This did not totally stop the seepage, but improved it to a manageable degree. My hands and fingers got really messy with the shellac, so I found it much easier to do with a helper--one person to keeping his hands clean to remove and reinstall the bolts, and one person painting the shellac on the threads with increasingly goopy hands. My differential is now slightly oily on the bottom from the seep, but seldom wet enough to drip. Before this treatment, I always had a huge grease spot on the floor and would have to top up the differential a few times each year.
W. Michael
w.michael is offline   Reply With Quote
Old 11-21-2017, 11:10 AM   #11
katy
katy's Avatar
Anyone ever use Loctite Quicktape 249 threadlocker tape? For bolts 1/4" and up.
Old 11-21-2017, 11:21 AM   #12
aermotor
I used Permatex Gear Oil Gasket Maker and it sealed every leaking bolt.
John
aermotor is offline   Reply With Quote
Old 11-22-2017, 12:25 PM   #13
woodlot1
when you chased the threads on the banjo housing you changed the pitch of the treads and that why they are leaking. install a good original banjo housing with original bolts. that should fix it. its lot of work. an old timer told me that me years
ago and he was right. evidently ford used a unique bolt and tread for that part and when you changed one component it leaks.
woodlot1 is offline   Reply With Quote
Old 11-22-2017, 02:08 PM   #14
CWPASADENA
CWPASADENA's Avatar
I tried everything
I finally rebuilt the differential
Side gaskets were in pieces
Made banjo surfaces flat and took very thin cut off of bell gasket surfaces, they were not flat, I have a machine shop
Now, every thing fine, no leaks
Try everything else first before disassembly
I am NOT a big fan of Silicone
My opinion
Chris W
CWPASADENA is offline   Reply With Quote
Old 11-24-2017, 06:39 PM   #15
jdpalmer
jdpalmer's Avatar
I had to drain the oil and cleaned the threads and just put some RTV on threads and no leaks
Jimmy Palmer
jdpalmer is offline   Reply With Quote
