09-09-2019, 09:23 PM | #1 |
What would identify a Brookville 1931 Roadster Body
If a seller did not know what he had or in a case I saw an estate auctioneer? What would be a quick dead give away? Gas tank? Do they use a different tank or you have to use an original? I don't think they sell any gas tanks as parts . Just something I was thinking about as I do know a local '31 roadster for sale and it is what is going to be seen more frequently an inheritance and a person who knows nothing about the cars restoration. I have posted about two others last spring that were local cars and I was told they were both Brookville roadsters on sedan chassis. At the time I never thought to ask or look at what would be different. They were both beautifull cars that sold very well.
"Never complain,never explain"... Henry Ford II |
09-10-2019, 02:42 AM | #2 |
Re: What would identify a Brookville 1931 Roadster Body
Spot welds instead of rivets, and the shape of the firewall around the engine area are the two biggest areas. The Brookville Roadster uses the original fuel tank.
09-10-2019, 02:51 PM | #3 |
The 28-29 seat supports are made by Brookville as "two intersecting circles." The original were punched as an "oval." It of course would take someone with a file/die grinder about a minute to remove the unpunched part - before the body is assembled.
After assembly - much more difficult and difficult to do without leaving evidence. Joe K
Shudda kept the horse. |
09-10-2019, 03:27 PM | #4 | |
09-10-2019, 04:38 PM | #5 | |
I asked the body vendor why Brookville didn't make the extra step and make the circles into ovals - since this is best done before assembly. His thought? "They have to have some way to make their bodies distinct from originals" - a valid point, although as some have said, there are other differences. At least with the ovals/round, one doesn't have to be any sort of expert. Joe K
09-10-2019, 07:59 PM | #6 |
A number of the more rare globes are flooding into the country today, newly made, from China and they have even fooled the experts on occasion, the novice quite often. They are doing the same with all sorts of rare American coins and especially the Morgan and Peace Silver Dollars. You gots -ta be super super careful they are getting harder to spot, and the fakes get better every year. Gold coins? Forget it lots of fakes out there. Maybe they need to badge the Brookville Roadster in a similar fashion somehow as people are going to be fooled. |
09-11-2019, 07:27 AM | #7 | |
To take a few comments in this thread a tad further, the original question is how do you tell the difference between original and repro. It was mentioned Seat Riser and pans are different. While that is a very true statement, I will say that the majority of original Roadsters that I have seen restored have repro floor pans and seat risers installed. If we went by Joe's telltale of incorrectly shaped seat risers, I would expect many original Roadsters would be incorrectly identified as a Brookville body. To confuse the masses, several years ago we actually had Brookville build our customer a Roadster using an indented Firewall that we had restored and sent them. I also had Brookville leave the floor pans out. We drilled holes in all the spotwelds and either installed rivets we bucked & waffled, or added weld and cammoflauged the ends to look like a factory rivet. We reshaped the pans and the doors in a Pullmax, and to my knowledge, no one to this day has ever questioned if that body was anything other than super nice original sheetmetal. We have also reworked reproduction fenders and body aprons where they looked just like original sheetmetal. Others have done the same thing, so if it will pass the muster in Fine-point adjudication, then it should be acceptable including in the sale of the vehicle providing the Seller does not use deceit in the sale. |
09-11-2019, 08:41 AM | #8 |
Since the Brookville bodies are that close to original, what difference does it make which one you have? Most people own an A for its appearance and the driving experience. If it looks and performs as original, does it really matter if the body panels were stamped in 1930, or in 1980, or in 2019? Does it matter if the crankshaft was made by Ford, or made by Burlington? Or if the upholstery was stitched in 1931 or in 2018? A quality reproduction body seems to be a better choice than an original rusted out one that's full of welded-in reproduction patch panels. Really, that patched body is not original either!
09-11-2019, 09:01 AM | #9 | |
To others being able to say "can you tell the difference?" (throwing a gauntlet) is worth their price. To others - "don't you like the ride and there are no body squeaks" floats their boat. Nobody can fault anyone else. Joe K
09-11-2019, 09:49 AM | #10 |
The best thing about Brockville bodies is that you can build a hot rod without destroying an original car.
09-11-2019, 10:46 AM | #11 |
@smogtech, or resurrect an old chassis and running gear from a hotrodder who just used the original body! I did exactly that.
09-11-2019, 12:29 PM | #12 | |
Brent I recall that Roadster you are talking about, the one your shop did, and it was spot-on, a beautiful car. I've been around Model A Fords since '71, and I didn't spot the difference until someone told me what the car was. I was VERY impressed to say the least it turned out beautifully |
09-11-2019, 04:26 PM | #13 |
what parts are you guys saying are "circles" or "ovals"?
09-11-2019, 05:07 PM | #14 |
Seat frame. At the juncture between the seat back and the seat bottom.
Below the repop seat frame for the 28-29 RPU. These holes they have "slotted" to make the oval. The Ebay seller is in Greenville Ohio, so probably associated with Brookville. Joe K
09-12-2019, 11:42 PM | #15 | |
The Brookville body costs about $7000.00 So I would say that cost would be the difference between original and Brookville.
09-13-2019, 01:19 PM | #16 | |
I also suppose that it depends on who installed the panels! Some craftsmen fabricate and install 'repair panels' while others install 'patch panels'. The name generally says it all!! . . |
09-13-2019, 01:38 PM | #17 |
I have a friend here in Ohio that bought a 32 Ford 3 window coupe about 10 years ago .The car was solid but stored since the fifties and for some odd reason someone in its past started to cut on the roof not som much to chop but too make a roadster out of it or something,luckily they quit before they got to the doors. He took the car to Brookville as they make a 3 window and repair panels and they did all the work.He actually had to pay for complete side panels to get the part that the car needed done but he took it to the right place.It is excellent looking and black so nothing is evident that normally would show. This guy is so lucky he also got a set of NOS disc brakes with another deal years ago and put them on this car.Kinmonts.
