Old 10-25-2017, 07:49 AM   #1
burl
Default weiand head
So im looking at purchasing an old weiand head.Two of the spark plug holes have been repaired and changed to 14mm.The other two are either 16mm x 1.5 or 5/8 18.Anybody know what size there are supposed to be ?I would like to make all of the plug holes the same.Just checking to see if anybody has had to make this repair and what they did.weiand 1.jpg
burl is offline   Reply With Quote
Old 10-25-2017, 09:56 AM   #2
Jim Brierley
Default Re: weiand head
Probably 18mm, a common size for aftermarket heads back in the day.
Jim Brierley is offline   Reply With Quote
Old 10-25-2017, 10:20 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
I have a near new one, never been cut the compression ratio is stamped in 2 places, on the gasket surface by the water pump --- if it's gone the head has been cut, mine is originally 8.5, if you look close it is stamped on the top between #2 plug and center stud hole, the plugs are 14 mm
Old 10-25-2017, 10:26 AM   #4
burl
I don't think this one was cut as we checked it to another one just like it.The depth to the combustion chambers is exactly the same.For some reason the previous owner removed the weiand lettering,must not wanted anybody to know what they were running.Just trying to find out what the plug size should have been.The orginals are either 16mm or 5/8 fine,not sure what plugs would fit that.
Old 10-25-2017, 10:29 AM   #5
burl
Jim,
already checked it with tap,seems like its 16mm or 5/8-18
Old 10-25-2017, 10:37 AM   #6
d.j. moordigian
d.j. moordigian's Avatar
I agree with what was written. Don't weld the plug holes,..do a "mechanical repair" and
please use anti-seize on the threads..
My head has 14mm plug holes. Does anyone know if the head is thick enough too put a
"quench area" above the piston so I can use stock pistons?
d.j. moordigian is offline   Reply With Quote
Old 10-25-2017, 11:22 AM   #7
Kurt in NJ
Kurt in NJ's Avatar
If it wasn't cut the compression ratio is stamped on the underside of the water pump boss, I will probably go where the head is and take measurements
It does look thick inside to be able to add a piston relief
It was common back in the day to enlarge plug holes to the next larger plug, snap on sold a spark plug tap set with a enlargeing reamer along with tap,
Old 10-25-2017, 01:34 PM   #8
closedcab30
want to purchase either a thomas head or other finned head suit model a motor , anything out there thanks ...310 340 5715
closedcab30 is offline   Reply With Quote
Old 10-26-2017, 09:52 AM   #9
d.j. moordigian
Thanks Kurt..
Old 10-26-2017, 10:13 AM   #10
burl
has anybody ever repaired the spark plug threads in a head ?Just wondering what was used and how it was done.I have been looking at the thread sert inserts instead of helicoils
Old 10-26-2017, 11:27 AM   #11
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by burl View Post
I don't think this one was cut as we checked it to another one just like it. Just trying to find out what the plug size should have been.
What is the plug size of the other head you are checking with?
Has anybody ever repaired the spark plug threads in a head ?Just wondering what was used and how it was done.I have been looking at the thread sert inserts instead of helicoils
Did a lot of Corvair heads in the past using heli-coils. No problems.
Old 10-26-2017, 02:28 PM   #12
burl
The original plug looks like it was 16mm or 5/8 fine.Both threads are very close to the same.I couldn't find and plugs that fit that size so I was thinking about changing all of them to 14mm which is a pretty standard plug.
Old 10-27-2017, 12:07 PM   #13
Jim Brierley
Burl, I have never heard of a 16mm plug, better check to see if they are available.
Old 10-27-2017, 12:15 PM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
X2
I wonder if it should be 18 MM, which used to be a common size.
Old 10-27-2017, 12:46 PM   #15
Chris Haynes
Chris Haynes's Avatar
Thread serts are far superior to heli coils.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 10-27-2017, 04:47 PM   #16
PC/SR
Mine has 14mm plugs, two cylinders of which have heli coils. There is no relief in the head for pop-up stock pistons. You can shave 030 off the pistons. DO check block height, from the pan rail to the deck. It may have been shaved in the past and the pop up may be more than stock.
PC/SR is offline   Reply With Quote
Old 10-28-2017, 05:54 AM   #17
Tod
Funny, I had a plan to make a top like this for the Weiand crow's foot chamber I use with my Winfields.
Tod
Tod is offline   Reply With Quote
Old 10-28-2017, 10:21 AM   #18
katy
katy's Avatar
Here's some modern 16mm plugs, my son's F-150 uses them
https://www.summitracing.com/int/par...view/make/ford
Old 10-28-2017, 11:14 AM   #19
Kurt in NJ
Kurt in NJ's Avatar
I was thinking, perhaps it is 16 mm because it was helicoiled, I have used helicoil taps for 2mm larger threads of the same pitch
Old 10-28-2017, 03:15 PM   #20
40 Deluxe
Those plugs will NEVER work in an A head, nor any head except that particular model Ford pickup 5.4 engine!!
