12-02-2018, 01:22 PM | #21 |
Re: Dual Overhead Cam Flathead
along the row of valves, since the valves open the other way (up for open, down for closed), are they opened by spring pressure and closed by the cam
Actually the opposite, The valves are opened up by the cam and closed by the spring pressure. The big advantage of this type of a cylinder head is airflow. It increases the performance of the Flathead which is limited by its original design. Remember also that the old valve pockets in the block will have to be sealed up for this to work. |
12-02-2018, 03:19 PM | #22 | |
12-02-2018, 07:27 PM | #23 |
It might be an interesting engine to some or maybe even many but to me it is no longer a flathead and therefore I am not interested. I am not bashing so please nobody get upset … just expressing my opinion.
12-02-2018, 07:32 PM | #24 |
That's how I look at it as well, cool technology, but no longer a flathead.
12-02-2018, 08:04 PM | #25 |
Oxymoron.
12-03-2018, 10:28 AM | #26 |
Pent roof" chamber which allows for a 'Squish" ares for increased compression. Probably the most famous engine of this type was the 4cy Offy that dominated Indy for decades. |
12-03-2018, 03:49 PM | #27 | |
Heck just consider it a fathead.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
12-03-2018, 04:04 PM | #28 | |
FWIW, the Ford flathead engine has its combustion chamber in the head, too. The location of the combustion chamber isn't what determines whether or not an engine is considered a "flathead".
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
