03-23-2021, 08:37 AM | #1 |
'40 headlight mounts
Looking for a source for original or good quality headlight mounts for a '40.
The buckets are fine, but the mounts have seen better days. Are those mounts look like they may common to other cars and years. |
03-23-2021, 11:25 AM | #2 | |
Re: '40 headlight mounts
The caged nuts spot welded to the fender?
03-23-2021, 06:02 PM | #3 |
I am referring to the adjuster ring held in by springs and the adjuster screws in which the seal beam mounts. I can post a photo if further clarification is wanted. Thank you.
03-23-2021, 07:17 PM | #4 |
