02-18-2011, 08:58 PM | #1 |
Interesting radiator experiement
I purchased a '29 that had what I thought at the time was a new Brassworks radiator. Upon closer inspection, I found that the radiator is an original, it has the 4 tubes (seamed tubes) with the funnel shaped neck (riveted to the top tank).
The temperature would read around 150* (no thermostat) under fairly level driving conditions at 70* air temperature. The problem is that it would tend to run hot when going up a 3 mile very steep hill. The temperature gauge would be at about 215* when I reached the top of the hill, air temperature 70*. I know it should be rodded out but thought I would just try something first. I ran white vinegar in it for about one week, terrible looking rusting gunk drained out. I then ran Purple Power (full strength) in it for about a week, drained out a lot of small flakes and fine sediment. Strained the Purple Power and ran it again for awhile (more flakes and gunk). Now on a 70* day I can go up the same 3 mile steep hill pushing the car hard and the temp. gauge will only go to 185*. I am not sure just what temperature would be reached with a perfectly clean radiator under the same conditions but it seems I have helped it considerably. I may have to have it rodded but a 30* gain is not bad for three flushings. By the way, prior to this I flushed the radiator twice with Prestone radiator flush. Absolutely nothing came out of the radiator but clear water. Save your money - use vinegar and Purple Power. |
02-19-2011, 01:10 AM | #2 |
Re: Interesting radiator experiement
Sounds like a cheap way to extend the time before major radiator work. Thanks for the tip!
02-19-2011, 09:16 AM | #3 |
I flushed my radiator with 1 gal of Simple Green : 2 gals of water. After a 40 mile run and fast idle for about 30 minutes, to push the temp to 200 degrees, some thick nasty greasy crud poured out. A second round with half the Simple Green and the radiator is squeeky clean. Lowered running temp a few degrees but I was still leary so bit the bullet for a new core.
02-19-2011, 09:19 AM | #4 |
How much $ should a re-coring cost typically?
02-19-2011, 09:31 AM | #5 |
Fellows on the EV8 Forum swear by the vinegar treatment. It's cheap and nothing to lose. JMO
Paul in CT |
02-19-2011, 10:47 AM | #6 |
The Radiator flushes of today, are regulated by the EPA, and are almost totally useless, as you have discovered. They are just a waste of money. Glad the vinegar worked well for you ! MIKE |
02-19-2011, 01:18 PM | #7 |
so did you run 100 % vineger ?? like you poured in gallons of the stuff straight ?? not that i think its wrong to do so im just asking so i can do it to . kinda like monkey hear monkey do
02-19-2011, 02:49 PM | #8 | |
I did get a little on the concrete drive and didn't get is hosed of before it dried, it now seems to be a permanent stain . Last edited by Gary/IA; 02-19-2011 at 03:21 PM. Reason: After the vinegar, I flushed the system with soda water. |
