Old 05-18-2017, 02:44 PM   #1
burly
burly's Avatar
Default Front Fender Question
Guys trying to determine if a 39 standard and a 38 deluxe front fenders are interchangeable? Appreciate any information you could share! Thanks
burly is offline   Reply With Quote
Old 05-18-2017, 03:13 PM   #2
swoopNZ
MEMBER EMERITUS
Default Re: Front Fender Question
39 standard LH inner fender has holes for supporting the horns.
38 deluxe horns sat under the radiator.
Otherwise pretty much the same.
Hope this helps.
Chris.NZ.
New Zealand.
swoopNZ is offline   Reply With Quote
Old 05-18-2017, 03:18 PM   #3
swoopNZ
MEMBER EMERITUS
And also the cut-outs for the hydraulic brake line support brackets.
