02-02-2013, 09:50 AM | #1 |
Polishing aluminum
I have heard that some people could polish aluminum reproduction Model A parts so that they passed for the original stainless steel. The piece around the horn button comes to mind. My current need is to clean up some aluminum Chevelle grill parts for which a buffing wheel could probably not be used. Any suggestions for hand cleaning them? They do not need to have a mirror-bright surface. Thanks.
02-02-2013, 10:06 AM | #2 |
Re: Polishing aluminum
I may be wrong but I think the Chevelle aluminum trip pieces are anodized making them difficult to re-polish.
02-02-2013, 10:10 AM | #3 | |
That Chevelle Aluminum grille was hard anodized. Anodizing molecularly bonds a sapphire (Al2O3) coating with a surface hardness of 9 Mohs on the part. Second in hardness to diamond. Good luck trying to cut through it! |
02-02-2013, 02:42 PM | #4 |
You can remove the anodizing by putting the aluminum trim in a solution of lye and water. It will bubble and fizz while the anodizing is being dissolved. Then you can wash it off and buff it on a polishing wheel. But the lye and water will completely dissolve the aluminum if you don't watch it. Just watch while it "cooks". And the gas it puts off is highly flammable.
I have also heard of using a strong oven cleaner to remove anodizing.
Don’t pick a fight with an old man. If he is too old to fight, he’ll just kill you. |
02-02-2013, 03:03 PM | #5 |
I am told that more than one high point cabriolet/ A400 has a polished aluminum frame to look like chrome.
Since the windows are not opened during judging you can not tell it is aluminum. Again, I am only told this. I do not know if it is factual. |
02-02-2013, 03:12 PM | #6 |
02-02-2013, 03:34 PM | #7 |
My Chevelle is a '64 (the first year for Chevelle), and the aluminum is not anodized.
My personal opinion on fine point judging is that it should be relaxed because of the rarity of good original parts. I suggest a 2-foot rule so that if a part appears to be original at that distance, it should be accepted. When I first helped with fine point judging as an assistant, there were 50 or more cars entered. Now it seems that there might be only 15 in the fine point class. |
02-02-2013, 07:54 PM | #8 | |
If you can't cut it, don't complain, train. The last comment is not a personal attack on you Richard, just a statement I heard years ago. |
