02-02-2013, 05:26 PM | #1 |
Fitting New Front Spring
I purchased a new spring a while ago. The catalog said:
"The top leaf sides may at times need to be slightly tapered to fit within crossmember." I haven't taken the old one out yet, as I'm hoping to do it in one shot. I have the new spring broken down right now and would like to grind it down prior to painting and lubing. How much should I grind down on the sides? |
02-02-2013, 06:40 PM | #2 |
Re: Fitting New Front Spring
What you are trying to do is prevent the spring from digging in the spring below. Just champer the end of the spring so when it is compressed it doesn't dig in. Also go to Napa and buy yourself some slipplate it is great stuff to paint the spring with.
Oklahoma City Model A Restorers Group. |
02-02-2013, 07:02 PM | #3 |
The instruction you quoted is referring to the top leaf of the spring. The outside edges of the top leaf need to be chamfered to fit the shape of the front crossmember of the car frame.
02-02-2013, 07:03 PM | #4 | |
Right... wondering how much they need to be ground down prior to painting. |
02-02-2013, 07:08 PM | #5 |
You may want to bevel the sides of the top leaf so it will seat properly in the cross member.
02-02-2013, 07:13 PM | #6 |
Some replacement springs are wider than originals, this helps it 'seat' in the crossmember |
02-02-2013, 07:18 PM | #7 |
02-02-2013, 10:07 PM | #8 |
Why don't you just clean up the top leaf of the old spring that is already tapered and install it on the new spring?
Rusty Nelson |
02-03-2013, 12:42 AM | #9 |
Should'nt a piece of oiled leather or welt be inserted on top of the new spring before installation?
02-03-2013, 06:01 AM | #10 |
No.
