Old 11-28-2023, 10:04 PM   #1
Bob from Northport
Bob from Northport's Avatar
Default 54 Mercury Front drum question
Anyone know where i can find front grease seals for a 54 Monterey stock drums??
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 11-29-2023, 12:03 AM   #2
miker98038
miker98038's Avatar
Default Re: 54 Mercury Front drum question
You asking about front wheel bearing grease? Or just suspension fittings?
miker98038 is offline   Reply With Quote
Old 11-29-2023, 09:32 AM   #3
Bob from Northport
Sorry. I'm looking for the grease seals for the inside of the drum
Bob from Northport
Northport, Michigan
Old 11-29-2023, 01:32 PM   #4
KULTULZ
KULTULZ's Avatar
Well, here is the problem ...
The 1954 MERC CHASSIS MANUAL calls for either of two seals and does not indicate exactly which is which.
Do you want the seals when you pull the drums or can you wait? The seal will have an INDUSTRY PN on it and will be able to be crossed. Is there a BEARING SPECIALTY SHOP in your area? Better chance of getting a better quality seal than from a box store.
- DISCLAIMER -
The above posted information is in my opinion only (IMO) and may contain copy and paste material(s).
In addition, any above tech information is supplied in good faith. No responsibility implied or otherwise can be accepted for the way others use or interpret provided data.
Your experience(s), opinion(s) and mileage may vary.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 11-29-2023, 04:05 PM   #5
Bob from Northport
I pulled off the LF drum yesterday. Someone has put alot of new pats in this car. But the seals they installed do not look right. The Chassis manual says the seal part number is 1190. But so far no luck. I have to clean and paint the drums, so time is not an issue. I'm going to measure the ID of the drum and go from there. The bearings have some kind of cheap thin grease on them.
Bob from Northport
Northport, Michigan
Old 11-29-2023, 04:25 PM   #6
Gene F
Gene F's Avatar
shoebox-central, or macsonline
Old 11-29-2023, 04:27 PM   #7
Gene F
Gene F's Avatar
O'reilly 450044, or 450067
Old 11-29-2023, 06:31 PM   #8
KULTULZ
KULTULZ's Avatar
Arrow Re: 54 Mercury Front drum question
Below is the application chart from the 1954-55 MERC CHASSIS CATALOG -
See if it shows large enough to read. It only gives sizing on one seal, so you will most likely have to go with the ID NO off the old seal, if it is correct.
Where I would try and source brngs/seals is a vendor such as -
https://bearingsdirect.com/oil-seals/
... where the quality of the seal should be much better over a CHI-COM offered at a box store.
- DISCLAIMER -
Old 11-29-2023, 06:39 PM   #9
KULTULZ
KULTULZ's Avatar
PRECISION SEALS seems to be a quality product. If off-shore, the quality may be excellent, depending on the manufacturer. It is just too difficult to operate a manufacturing company here as the government will regulate and tax them to death
- DISCLAIMER -
Old 11-30-2023, 02:13 AM   #10
mobileparts
1954 is a one year only —- I have *** U S A made *** ones….
Always best to simply call me —- 516 - 485 - 193five —- Craig….
mobileparts is offline   Reply With Quote
