06-19-2020, 09:10 AM | #1 |
steering shaft coupling for my 34 pickup
Does anyone know of a non-weld on coupling (u-joint), to couple two 3/4" shafts end to end, that will fit inside steering tube? I dont really want the u-joint to show. I think i will need the little angular misalignment leeway allowed by the u-joint. I have an f-1 shaft and wheel that almost reaches the steering box. and i am using an f100 steering box. My project was no way a candidate for restoration and I am just trying to get this old hotrod back on the rod. appreciate any knowledge passed on. Frankie
06-19-2020, 10:19 AM | #2 |
Re: steering shaft coupling for my 34 pickup
normally, either an f1, or an f100 shaft and box can be made to run in a straight line like the 34 was originally by correcting the mount on the frame, not by putting a u joint in the shaft. how is your box mounted?
06-19-2020, 11:05 AM | #3 |
As for adding a u-joint, it really needs to be the D or double flat-side style to be safe. This could be done with a little effort and a hand grinder. Last edited by JSeery; 06-19-2020 at 11:14 AM. |
