Old 11-18-2016, 09:34 PM   #1
DJ S
DJ S's Avatar
Default Front Spring Perch Removal
I'm entirely rebuilding my front axle and now I've gotten to the point where I need to remove the front spring perches. One came out no problem but the other one won't budge. It looks like someone has been at this before and the threads are slightly mushroomed. I've been soaking it with PB blaster and have applied heat from a propane torch but nothing seems to be doing anything. Any suggestions and is there any hope in saving the slightly mushroomed threads?
DJ S is offline   Reply With Quote
Old 11-18-2016, 11:15 PM   #2
larrys40
Default Re: Front Spring Perch Removal
try and get the nut back on and make it flush with the end of the perch thread. I would soak it very good with Kroil penetrant, or Gibbs.. Sometimes they are difficult to remove. I recently had one that was a challenge and managed to save everything. It took quite a bit of soaking, and I applied heat to the area around the axle where the purch is several times. It finally came. I use a large brass hammer so it doesn't damage the threads so much. There is a special press type puller made by snap on ( you must have the correct adapter type) that can be used as well if obtainable.
Soak a lot, heat if need be.. and keep at it systematically. It will come out. Inspect the axle and wishbone well for straightness on both once removed.
Best wishes for removal!
Larry Shepard
larrys40 is offline   Reply With Quote
Old 11-18-2016, 11:33 PM   #3
700rpm
700rpm's Avatar
Larry Shepard
Isn't there risk to the temper of the axle by applying heat?
Ray Horton, Portland, OR
Old 11-19-2016, 01:14 AM   #4
larrys40
You guys can think so but honestly you do what you have to do to get it out... and I've never had a problem with an axle breaking (LOL)in two or even bending because of it. Many things get overthought....
Of course you can use a press if they have one but have to be careful as well.
Ray, have you ever removed a difficult one?
Larry
Old 11-19-2016, 01:20 AM   #5
Mike V. Florida
Mike V. Florida's Avatar
King pin would just not come out.
Old 11-19-2016, 01:22 AM   #6
larrys40
good one Mike... it must have fell out on one of the twists? Was this one of the original demonstrator axles?
Larry
Old 11-19-2016, 01:32 AM   #7
Mike V. Florida
Larry
That was what I was told,
Old 11-19-2016, 02:59 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
That's what happens when the brake locks up on one side.
Old 11-19-2016, 10:57 AM   #9
700rpm
700rpm's Avatar
Larry
I've been lucky; I've only had one really tight one. I soaked it with PB, then reversed the nut and gave it a few good whacks and it came loose.
Old 11-19-2016, 01:01 PM   #10
Bob C
Ever wonder how they make a dropped axle.
Old 11-19-2016, 04:41 PM   #11
bbrocksr
No heat. I welded 2 short pieces of flat bar with 5/8 holes to a 6' length of 1 1/2" pipe. Put a 5/8 bolt through the 2 pieces of flat bar and the shackle bushing hole and tighten securely. Now you have 6' of leverage to rotate the perch bolt back and forth using a lot of penetrating oil until loose enough to tap out.
I built this tool because I had a lot of front axles to disassemble and I didn't want to use heat. Worked good! Bill
bbrocksr is offline   Reply With Quote
Old 11-19-2016, 05:41 PM   #12
zzlegend
zzlegend's Avatar
A guy I know brought his axle and wishbone assemble over to me and I used my 5 ton hydraulic press and had to add a little heat to get them out.
Cant remember who made this but I might make one next time. Worth a try.
zzlegend is offline   Reply With Quote
Old 11-19-2016, 06:21 PM   #13
Big hammer
Thats a cool looking tool!! Tools are good
DJ S this might be a good time to try the suck candle wax up in axle bushing, someone posted a u-tube link last week. Let us know how,when you get it apart :-)
Old 11-19-2016, 09:18 PM   #14
Tom Wesenberg
Yep, that is a great looking tool. It's always better to pull than to push a stuck part, if possible, and that looks like the perfect tool for the job.
Old 11-19-2016, 09:26 PM   #15
zzlegend
zzlegend's Avatar
If any body can make one, that would be you Tom. And yes, pulling would be much better than pushing. I think I seen this on the hamb some time ago. Hope who ever made it doesn't mind if I borrowed the picture.
