11-17-2019, 09:43 AM | #1 |
Thread sealant
I am about to replace the original cast iron heads on an 8ba V8. I have a question regarding which thread sealant to use. I have both of the pictured products on hand. I also have read some of the prior posts on thread sealants. I am not necessarily asking which is the superior product, I am only inquiring whether both are satisfactory for this use. Thanks for any input.
11-17-2019, 10:01 AM | #2 |
Re: Thread sealant
I have primarily used the #2 non-hardening the other has teflon in it but either one will be satisfactory.
11-17-2019, 10:19 AM | #3 |
Re: Thread sealant
Along with applying to the bolts I also smear the threads in the block as much of the sealant from the bolts will be left on top of the block when you screw them in.
11-17-2019, 10:38 AM | #4 |
Re: Thread sealant
This works great also for head bolt and studs threads.
11-17-2019, 11:56 AM | #5 |
Re: Thread sealant
Thank you for your responses.
11-17-2019, 05:11 PM | #6 |
Re: Thread sealant
11-18-2019, 07:20 AM | #7 |
Re: Thread sealant
Me, I'd use the thread sealant with PTFE. Also, put a good amount of anti-seize on the sides of the bolts and a little bit of moly-lube/grease under the heads to help with more accurate torque readings.
Also, no matter which sealer you use - let the engine sit for at least a day before you fire it up . . . helps stuff harden a bit. |
11-18-2019, 07:27 AM | #8 |
Re: Thread sealant
Thanks again for all the input.
11-18-2019, 05:26 PM | #9 |
Re: Thread sealant
Thread sealant for me .......
