11-03-2018, 06:49 PM | #1 |
1935 signal lights
There are signal lights on top of the headlights ('35 ford truck) but no signal lever on the column. Why?
11-03-2018, 06:54 PM | #2 |
Re: 1935 signal lights
An original 35 Ford would not have turn signals. Turn signals were not added until much later. Does it have Guide type headlights installed?
11-03-2018, 07:06 PM | #3 |
11-03-2018, 07:34 PM | #4 |
Those headlights are not stock to your pickup. The lights on top were parking lights. The lights were made by Guide company and they made a lot of items for General Motors. if you like them on your truck then you can use the top lights for a signal lights. All you need is a switch and then use both stop lamps if you have two on your truck.
11-03-2018, 07:36 PM | #5 |
