03-29-2019, 04:31 PM | #1 |
39 coupe grease
Stupid question. The drive shaft zert - regular grease and how u know when is enough?
Thanks Andy 1952 F1 |
03-29-2019, 05:06 PM | #2 | |
Re: 39 coupe grease
Normally I grease around 400 to 500 mls interval. For that one normally give 5 to 6 pumps on the grease gun. Got to use a bit of faith here as you are aware not able to see excess squeeze out at at king pins or steering. Sometimes resistance on grease gun lever can indicate if space is full. Phil NZ |
03-29-2019, 05:07 PM | #3 |
Re: 39 coupe grease
Phil thanks!
03-29-2019, 05:20 PM | #4 |
Re: 39 coupe grease
Pump it until the grease comes out of the road draft tube
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
03-29-2019, 05:22 PM | #5 |
Re: 39 coupe grease
Here is what that drive shaft center bearing looks like. It doesn't hold a lot of grease, perhaps 1 or 2 squirts. Look carefully and you can see the leather seal on each side of the bearing. Very easy for grease to squirt through it.Too much grease will damage the rubber cushion by dissolving it.
I would use the same fiber grease used on the rear wheel bearings. First 2 photos show center bearing with dissolved rubber casing removed. Next 2 photos shows what I removed from my torque tube. The metal bearing is in that pile of "goo". Last photo is center bearing remove/install tool. I had rear end fluid leaking into the torque tube which, i am sure, also added to the center bearing problem. Last edited by 19Fordy; 03-29-2019 at 05:46 PM. |
03-29-2019, 05:50 PM | #6 |
Re: 39 coupe grease
I’ll return the favor to Alan no road draft tube on 39
03-29-2019, 06:50 PM | #7 |
Re: 39 coupe grease
